Sense Energy has been integrated in the Cloud page, Sense tab of mcsMQTT. It provides the ability to update HS devices at a user-specified rate form the Sense Energy Cloud server and to deliver graphics for historical trends. To use this feature a user needs to have Sense Energy hardware and an account with Sense Energy that is setup when the hardware is registered. The plugin also provides access to device information, device isolation status, and timeline of device changes. These additional features are not automatically available as HS devices, but are viewable for association to HS via the MQTT Page, Association tab. It also provides a conduit to know what device, status and timeline information is available from the server so future plugin enhancements can be made.
The energy consumers are presented as HS Devices
All Sense Energy information is available on the mcsMQTT Assocaition tab of the MQTT Page where it can be associated with HS deivce, if desired.
If the current energy use of a sense consumer (i.e. payload column hyperlink) is clicked then a new page is drawn with the historical energy use. The periods of time can be selected for additional views from this page. This is data from the Sense server and not collected in mcsMQTT databases. It is somewhat awkward with very little information at the beginning of the reporting cycle. The chart is presented in local time while the Snese server collects data in the UTC time representation.
This is relatively early in the Sense Energy integration so quite welcome to changes to improve the usability.
The GW1000 interface has been augmented with up to two derived sensors for dewpoint and feels like if the sensors are available to support these derived calculation.
A more significant change under the hood is the method by which concurrent access to the same data is handled. I have been running this update for a few days without issue. It seems some things may take longer such as deletion of obsolete topics. This is due to the lockout mechanisms employed to assure a dictionary of data is not being changed when it is being used.
This is version 5.20.0.1 which is an incremental change from 5.191.0 that is available from the HS Updater. The HS4 zip file has an html file that replaces the one in the HS subfolder \html\mcsMQTT. Both have the replacements for the \bin\mcsMQTT folder
HS3: http://mcsSprinklers.com/MCSMQTT_52001.zip
HS4: http://mcsSprinklers.com/MCSMQTTHS4_52001.zip
