I have recently moved my Mosquito to another machine and i need to change the broker IP address in the plugin. When I click the "General" tab in the plugin it locks up and i am not able to access settings. I have removed the plugin and reinstalled. Same result, it seems some sort of setting remains after the uninstall/reinstall. Please advise.
Cannot access configuration
Settings are not affected by install or upgrade. There has been change in how concurrency is managed to protect data integrity when user is access the data and MQTT is updating the data. What is the plugin version you gave been using? You can also edit \Config\mcsMQTT.ini to change the Broker IP so next time mcsMQTT starts it will have the new Broker address. There is also a debug setting that will collect data in \data\mcsMQTT\mcsMQTT Debug.txt to get a view of what is happening under the hood.
- Likes 1
