Strange message in the logs
    Hi Michael,
    Been using the plugin with a Broadlink RM4 Pro for some time now, commands work fine. But I took a look at the HS4 log tonight and I see a strange message every time I issue a command (2nd line from the top in the log), yet the commands work. What does it mean?
    This is coming from a receive thread of a messages topic starting with "Broadlink/". I will look further, but confirm that the sequence started with something to send IR to endpoint "Candles". It likely is that I should not be processing the /set messages from Broadlink control since these are not real messages and there is not feedback from the Broadlink interface that the IR was actually recognized by some device.
      Correct, the log reads from the bottom up in terms of time sequence, there is a learned IR "Off" command that is sent from the Broadlink to some LED candles. As stated, everything works fine except for the Info message in the log.
        I see in the manual where I indicated that HS commands to Broadlink device were also sent via MQTT. I forgot why, but I suspect to sync remote clients so they know the IR was sent. I did fix the log problem with 2.21.0.2
        HS3: mcsSprinklers.com/MCSMQTT_52102.zip
        HS4: mcsSprinklers.com/MCSMQTTHS4_52102.zip
          Thanks Michael McSharry , since it's not affecting functionality I'll wait until it's in the HS updater. Thanks for looking into this!
