I setup a test with Segment 0 with 0 to 9. Segment 1 with 0 to 5 and Segment 2 with 6 to 9 on WLED 0.12.0. I controlled Segment 1 from HS Devices. First the color picker. Then twice with the Hue control. In all cases I obtained the expected JSON and RGB/HSB conversions. The first line is command sent from HS. The next four lines are the response from WLED with which the HS color and HSB slider devices were updated. I did the evaluation using HS3 plugin on both HS3 and HS4 with the same result. I do not now have the JSON communication in the debug log. I was using VS Debugger to capture it. I added the JSON command and response t the debug in the attached it if you continue to have issue.
Segment 1 color to blue HSB = [COLOR=#0000ff]240,100,100[/COLOR] "{""on"":true,""bri"":250,""transition"":7,""ps"":3,""pl "":-1,""ccnf"":{""min"":1,""max"":5,""time"":12},""nl"":{""on"": false,""dur"":60,""fade"":true,""mode"":1,""tbri"":0,""rem"" :-1},""udpn"":{""send"":false,""recv"":true},""lor"":0,""mains eg"":0,""seg"":[ {""id"":0,""start"":0,""stop"":9,""len"":9,""grp"":1,""spc"" :0,""on"":true,""bri"":255,""col"":[[28,255,8],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}, {""id"":1,""start"":0,""stop"":5,""len"":5,""grp"":1,""spc"" :0,""on"":true,""bri"":127,""col"":[[[COLOR=#0000ff]0,0,255[/COLOR]],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}, {""id"":2,""start"":5,""stop"":9,""len"":4,""grp"":1,""spc"" :0,""on"":true,""bri"":255,""col"":[[28,255,8],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}]}" Segment 1 hue to 360 (red) RGB = [COLOR=#c0392b]255,0,0 HSB = 0,100,100[/COLOR] "{""on"":true,""bri"":250,""transition"":7,""ps"":3,""pl "":-1,""ccnf"":{""min"":1,""max"":5,""time"":12},""nl"":{""on"": false,""dur"":60,""fade"":true,""mode"":1,""tbri"":0,""rem"" :-1},""udpn"":{""send"":false,""recv"":true},""lor"":0,""mains eg"":0,""seg"":[ {""id"":0,""start"":0,""stop"":9,""len"":9,""grp"":1,""spc"" :0,""on"":true,""bri"":255,""col"":[[28,255,8],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}, {""id"":1,""start"":0,""stop"":5,""len"":5,""grp"":1,""spc"" :0,""on"":true,""bri"":127,""col"":[[[COLOR=#c0392b]255,0,0[/COLOR]],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}, {""id"":2,""start"":5,""stop"":9,""len"":4,""grp"":1,""spc"" :0,""on"":true,""bri"":255,""col"":[[28,255,8],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}]}" Segment 1 hue to 188 (cyan) [COLOR=#3498db]RGB = 0, 221, 255 HSB = 188, 100, 100[/COLOR] "{""on"":true,""bri"":250,""transition"":7,""ps"":3,""pl "":-1,""ccnf"":{""min"":1,""max"":5,""time"":12},""nl"":{""on"": false,""dur"":60,""fade"":true,""mode"":1,""tbri"":0,""rem"" :-1},""udpn"":{""send"":false,""recv"":true},""lor"":0,""mains eg"":0,""seg"":[ {""id"":0,""start"":0,""stop"":9,""len"":9,""grp"":1,""spc"" :0,""on"":true,""bri"":255,""col"":[[28,255,8],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}, {""id"":1,""start"":0,""stop"":5,""len"":5,""grp"":1,""spc"" :0,""on"":true,""bri"":127,""col"":[[[COLOR=#3498db]0,221,255[/COLOR]],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}, {""id"":2,""start"":5,""stop"":9,""len"":4,""grp"":1,""spc"" :0,""on"":true,""bri"":255,""col"":[[28,255,8],[0,0,0],[0,0,0]],""fx"":0,""sx"":128,""ix"":128,""pal"":0,""sel"":true,""rev "":false,""mi"":false}]}"
