Had a few problems installing mcsMqtt, on HS4 also tried mcsShelly without success. Eventually McsMQTT installed ok and found two shelly dimmers and a temperature and humidity sensor, I also had a shelly motion sensor, which it found, but reported battery as 0% and Lux as 0%.
The HomeSeer log has an entry from mcsMQTT as follows:
ProcessMessage New shellies/shellymotionsensor-60A423975B58/info={ "wifi_sta": {"connected": true,"ssid": "Gibbet Secure","ip": "10.0.0.158","rssi": 0},"cloud": {"enabled": false,"connected": false},"mqtt": {"connected": true},"time": "00:00","unixtime": 1634833369,"serial": 0,"has_update": false,"mac": "60A423975B58","cfg_changed_cnt": 0,"actions_stats": {"skipped": 0},"sleep_time": 0,"lux": {"value":272,"illumination": "twilight","is_valid": true},"sensor": {"vibration": false,"motion": true,"timestamp": 0,"active": true,"is_valid": true},"bat": {"value":100,"voltage": 4.195},"charger": true,"update": {"status": "unknown","has_update": false,"new_version": null,"old_version": "20211004-105639/v2.0.2@7eba4128","beta_version": null},"ram_total": 97280,"ram_free": 22720,"fs_size": 65536,"fs_free": 59632,"uptime": 5,"fw_info":{"device":"shellymotionsensor-60A423975B58","fw":"20211004-105639/v2.0.2@7eba4128"},"ps_mode": 0,"dbg_flags": 0 } at MCSMQTTHS4_2020.Shelly.ProcessPayload (System.String sValue) [0x0030b] in :0 at MCSMQTTHS4_2020.ProcessMessage..ctor (uPLibrary.Networking.M2Mqtt.Messages.MqttMsgPublishEventArg s eventArg, System.Int32 iPubBroker) [0x00409] in :0 Line 0 Index was outside the bounds of the array.
This message only appears once unless I either reboot the device from its web page or disable/re-enable MQTT on the device. even if the message appears again, the time does not alter on the device page (I unticked Last Change Time Updates on Status Change Only)
