Hi, Just upgraded to 5.23.5.0 and see this multiple times in the HS log v4.2.8.0. So far all are for this Shelly Uni device....
ProcessMessage New shellies/shellyuni-E8DB84D247EC/ext_temperatures_f={"0":{"hwID":"28692adb0c000020","tF":53.9 },"1":{"hwID":"28d505db0c0000cd","tF":58.0}} at MCSMQTTHS4_2020.Shelly.ProcessPayload(String sValue) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\Shelly.vb: line 210 at MCSMQTTHS4_2020.ProcessMessage..ctor(MqttMsgPublishEventArgs eventArg, Int32 iPubBroker) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\ProcessMes sage.vb:line 113 Line 210 Index was outside the bounds of the array.
When HS starts, this shows up once:
ProcessMessage New shellies/shelly1-500291ED11CD/info={"wifi_sta":{"connected":true,"ssid":"xxxx","ip":"10.0. 0.41","rssi":-73},"cloud":{"enabled":false,"connected":false},"mqtt":{"con nected":true},"time":"","unixtime":0,"serial":1,"has_update" :false,"mac":"500291ED11CD","cfg_changed_cnt":0,"actions_sta ts":{"skipped":0},"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_dura tion":0,"timer_remaining":0,"source":"mqtt"}],"meters":[{"power":0.00,"is_valid":true}],"inputs":[{"input":0,"event":"","event_cnt":0}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"up date":{"status":"unknown","has_update":false,"new_version":" ","old_version":"20211109-124958/v1.11.7-g682a0db"},"ram_total":50880,"ram_free":38824,"fs_size":2336 81,"fs_free":151353,"uptime":1334428} at MCSMQTTHS4_2020.Shelly.ProcessPayload(String sValue) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\Shelly.vb: line 210 at MCSMQTTHS4_2020.ProcessMessage..ctor(MqttMsgPublishEventArgs eventArg, Int32 iPubBroker) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\ProcessMes sage.vb:line 113 Line 210 Index was outside the bounds of the array.
