Michael, I was several version behind so upgraded to the latest HS3 version today( It shows 5.23.21.2 despite down loading 5.23.21.3). It appears that now each time your plugin receives MQTT data it puts it in the HS3 Log. This is great for Debugging but is there a way to turn it on/off so it only does that when I need it. I looked and did not see an option.
Also, I noticed after upgrading the LOCAL->GW1000 section had Disconnect from GW1000 checked, prior to upgrade Connect to GW1000 was checked. Now for the really odd part. Even though Disconnect was checked it was still connected and receiving data.
