Hi,
I've just set up a Shelly with power monitoring using MSQTT.
I note the following in the log;
It looks as though it is trying to access a laptop - not me!
Plugin 4.28.0.8
ProcessMessage New shellies/shelly1pm-8CAAB574CD81/info={"wifi_sta":{"connected":true,"ssid":"Sunnydale","ip":" 192.168.1.87","rssi":-60},"cloud":{"enabled":false,"connected":false},"mqtt":{"con nected":true},"time":"","unixtime":0,"serial":1,"has_update" :false,"mac":"8CAAB574CD81","cfg_changed_cnt":0,"actions_sta ts":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_ dur ation":0,"timer_remaining":0,"overpower":false,"source":"inp ut"}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp ":0 ,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":0,"event":"","event_cnt":0}],"temperature":38.27,"overtemperature":false,"tmp":{"tC": 38. 27,"tF":100.88, "is_valid":true},"temperature_status":"Normal","ext_sens ors" :{},"ext_temperature":{},"ext_humidity":{},"update":{"status ":"unknown","has_update":false,"new_version":"","old_ver sion ":"20220209-094317/v1.11.8-g8c7bb8d"},"ram_total":50456,"ram_free":39036,"fs_size":2336 81,"fs_free":149094,"uptime":3} at Newtonsoft.Json.Linq.JObject.Load(JsonReader reader, JsonLoadSettings settings) at Newtonsoft.Json.Linq.JObject.Parse(String json, JsonLoadSettings settings) at Newtonsoft.Json.Linq.JObject.Parse(String json) at MCSMQTTHS4_2020.Shelly.ParseShellyJSON(String sValue) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\Shelly.vb: line 140 at MCSMQTTHS4_2020.Shelly.ParseShellyJSON(String sValue) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\Shelly.vb: line 164 at MCSMQTTHS4_2020.Shelly.ProcessPayload(String sValue) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\Shelly.vb: line 219 at MCSMQTTHS4_2020.ProcessMessage..ctor(MqttMsgPublishEventArgs eventArg, Int32 iPubBroker) in C:\Users\Public\Documents\LaptopVM\MCSMQTT2020HS4\ProcessMes sage.vb:line 113 Line 0 Error reading JObject from JsonReader. Current JsonReader item is not an object: StartArray. Path '', line 1, position 1. |
Plugin 4.28.0.8
