I recently installed mcsMQTT on my HS4 Windows 10 System. Everything seems to be running fine with mcsMQTT except for the CPU is very high. I have Restarted the Plugin and the system CPU drops to under 7%. 10 minutes to 15 minutes later, the CPU Spikes up again and stays that way for Hours (until I restart Plugin again).
I searched through the Forums and I selected he following settings (to see if that helped, and it dosent):
I have attached a Debug Log (Redacted).
- Listen for Only Associated and MQTT Trigger Topics
- Enumerate HS Devices only with Button
- Save history Of only devices marked With L or S column checkbox
