Stopped mcsMQTT, updated to 5.26.5.4, and it states "Loaded remotely." Seems to be working, though. What does that mean "Loaded remotely?" Thanks.
"Loaded remotely" v. 5.26.5.4
Intuitively it would seem that HS thinks the plugin has connected from an IP other than localhost or was started by a means other than via HS. I see this status when I run the plugin via Visual Studio. The status comes from HS and not the plugin so it is just a guess as to why it is showing what it is showing.
Originally posted by Michael McSharry View PostIntuitively it would seem that HS thinks the plugin has connected from an IP other than localhost or was started by a means other than via HS. I see this status when I run the plugin via Visual Studio. The status comes from HS and not the plugin so it is just a guess as to why it is showing what it is showing.
