I often see messages like the one below in the log, everything appears to work but.....!
ProcessMessage New shellies/shellybutton1-E8DB84D43082/sensor/act_reasons=["periodic"] at Microsoft.VisualBasic.CompilerServices.Symbols.Container.Get Members(String& MemberName, Boolean ReportErrors) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.Object LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at MCSMQTTHS4_2020.ProcessMessage.GetJSONArrayKeyList(String sValue) in C:\Users\Public\Documents\TFVC\HS\MQTT\MCSMQTTHS4_2020\Proce ssMessage.vb:line 666 at MCSMQTTHS4_2020.ProcessMessage.GetPayloadList(String sValue) in C:\Users\Public\Documents\TFVC\HS\MQTT\MCSMQTTHS4_2020\Proce ssMessage.vb:line 644 at MCSMQTTHS4_2020.ProcessMessage..ctor(MqttMsgPublishEventArgs eventArg, Int32 iPubBroker) in C:\Users\Public\Documents\TFVC\HS\MQTT\MCSMQTTHS4_2020\Proce ssMessage.vb:line 138 Line 0 Public member 'Type' on type 'String' not found.
Hope that is helpful.
