Michael, is there anything that can be done on the plugin side to correct this issue, or is it an HS4 problem? I've tried tinkering with a few display settings on my PC without success.
Display issue
I assume you are referring to the overwrite in the dropdown list. If this is the case then it looks to be related to the javascript/css used in the HTML. I used the template provided by HST in their original HS4 sample plugins for the dropdown code and never looked under the hood. I would take a look at the HTML from the browser (F12 is what I use to do this) and look for anything that looks odd in the select list.
