You kindly upgraded mcqMQTT back in January to improve the elevating of topics for wildcard support of multiple DS18b20 thermometer sensors and I was running the hotfix version you generated for several months:
PR808 1/28/2022 5.23.1.4 Added option to elevate wildcarded keys for device uniqueness
However, I recently used the HS3 plug-in updater to obtain the latest mcsMQTT and things went downhill after that and have not been the same since.
I tried completely removing the mcsMQTT.db and mcsMQTT.ini to start afresh and I now receive "Cannot elevate JSON key 1 because if does not exist in Topic sonoff-5967/SENSOR/DS18B20-1:Id" or "Cannot elevate JSON key 2 because if does not exist in Topic sonoff-5967/SENSOR/DS18B20-1:Id" as per the screenshot if I try to elevate a topic.
Is there a clean way of starting from fresh or something else I should try?
