Looking for guidance on what to enter into mcsMQTT Plugin. I am working my way through the manual.
7:03:17 AM Topic homeassistant/light/0xb0ce18140001de1b/light/config Payload {"brightness":true, "color_temp":true, "xy":true, "schema":"json", "command_topic":"zigbeeWA/SengledColor/set", "state_topic":"zigbeeWA/SengledColor", "name":"SengledColor_light", "unique_id":"0xb0ce18140001de1b_light_zigbeeWA", "device":{"identifiers":"zigbee2mqtt_0xb0ce18140001de1b", "name":"SengledColor", "sw_version":"Zigbee2mqtt 1.2.1", "model":"Element Plus Color (A19) (E11-N1EA)", "manufacturer":"Sengled"}, "availability_topic":"zigbeeWA/bridge/state"}
