Hi Michael,
not sure if this is related to my HS4 migration, changes to the plugin or an increase in my number of devices/polling, but I started having issues with HS/MCSMQTT response time.
I did read your documentation + performance tips; made some changes and troubleshooted for a while and it's clearly related to the MCSMQTT queue filling up.
switched some devices to Express mode, disabled local graphs/history (still use Influx) and tried a number of general/queue settings unsuccessfully (current queue settings below).
Before I look for a CPU upgrade, I'm quite puzzled why the plugin gets hits by so many callbacks (?) for rather basic usage.
Have a look below, the first spike is the result of triggering a single motion sensor + associated event (below)
If I continue moving across the house, this gets ugly quite rapidly as you can see on the graph.
And obviously HS response time deeply suffers while this is happening.
Why so many callbacks (close to 600 for a single event!?) does this look normal?
If so, (don't think so as I didn't have these issues before) what are my options to improve performance ; CPU upgrade or other?
If not, how can I troubleshoot further to fix this ?
Thanks again for your support on the recent testing/troubleshooting spree =)
