I recently installed Home Assistant on a virtual machine (using my HomeSeer computer's Windows 10 Pro system).
I created a Mosquitto broker on Home Assistant and with the help of your documentation managed to get HomeSeer to connect to this broker.
From the HS log file: MQTTClient is Connected to broker 1 at 192.168.1.248 (which is the IP address of my virtual machine running Home Assistant).
From here I'm running into difficulty as where to start. Do I create HS virtual devices and configure the plugin somehow to update these devices from individual Home Assistant devices? I thought there was a way to auto create HS devices.
Just looking for a starting push to go in the right direction.
BSR
BSR
