The H&T is an attractive sensor of about 1.5" diameter that reports humidity, temperature and its battery life. It reports periodically or when a change in a sensor reading exceeds a threshold.
No user configuration is necessary, but some options are available as documented at https://shelly-api-docs.shelly.cloud/#shelly-h-amp-t Since it is a battery powered device it needs to be awaken if additional configuration is to be done. It is awaken by pressing its button. The button is accessed by twisting the top. This is also the mechanism used to change the battery when necessary, but this should only need to be done annually.
Just like all Shelly devices the H&T contains it own HTTP server for easy browser configuration access. In this example the assumption is that the IP on the network is 192.168.0.123. Since this likely will not be the IP of your H&T just change the examples below appropriately.
http://192.168.0.123/settings?temperature_unts=F http://192.168.0.123/settings?temperature_unts=F&sleep_mode_period=4
Shelly HT accepts the following extra parameters on it's /settings endpoint: Parameters
temperature_units | string | Either 'C' or 'F' |
temperature_threshold | number | Temperature delta (in configured degree units) which triggers an update |
humidity_threshold | number | RH delta in % which triggers an update |
sleep_mode_period | number | Periodic update period in hours, between 1 and 24 |
