Having problem setting up new DuoBulb in plugin.
Bulb registered on my wifi and assigned manual IP.
Can access and change settings on bulb webpage OK and the bulb reacts appropriately.
1st time I configured bulb webpage settings to activate MQTT, mcsShelly plugin created devices for the bulb and I could turn the bulb on and off but the brightness (slider) and color (submit) settings would not work... after requesting those to change from the HS3 web control page, after 15 seconds or so the bulb would go off and then back on without changing brightness or color and the HS3 device settings would return to the prior value.
After disabling and re-enabling the plugin couple times with no improvement, I unchecked all the association table "a" columns for the bulb and disabled/re-enabled the plugin... the "a" column boxes were rechecked, but the bulb devices are no longer appearing in the HS3 web control page... for Room filter, the "ShellyBulbDuo-664A7C" that previously appeared is now missing. While previously, the "Dev:" value in the association table showed "shellies|ShellyBulbDuo-665A7C|ShellyBulbDuo-664A7C-xxxx where xxx's are energy, power, etc, the "Dev." values now show as: Unknown. Payload values do show the current states of the bulb which I can change from the bulb's webpage. The HS reference numbers shown in the association table have not changed but do not show in Jon00 Device Viewer as assigned reference numbers.
Wondering:
1. Why the on/off worked but the brightness slider and color temp setting submit would not work?
2. Now that I've probably screwed up mcsShelly settings somehow, suspect I need to remove the bulb from the plugin somehow so it can be rediscovered cleanly?... how do I do that?
PS: Plugin is working for a Shelly Relay Switch installed several months ago. I have no MQTT knowledge so I haven't a clue here...
Wondering:
