Did You Perform a Factory Reset On Your Insteon Hub?
    38
    Yes, I performed the 10 second factory reset and my hub STILL WORKS
    18.42%
    7
    Yes, I performed the 10 second factory reset and my hub NO LONGER WORKS
    0%
    0
    Yes, I ran the plugin Interface/Reset Interface routine and my hub STILL WORKS
    13.16%
    5
    Yes, I ran the plugin reset and reprogram routine and my hub NO LONGER WORKS
    0%
    0
    No, I did not factory reset my hub
    65.79%
    25
    Other (please explain below)
    2.63%
    The poll is expired.
    Learn About HomeSeer
    if you do hard reset accidentally - try power cycling couple of times and most importantly waiting a good 10-20 minutes then mine finally posted IP address. Not all hope is lost as mine survived but I did not know the risk. Additionally I did the plugin reset too lol.
      Interface reset
      But thinking to try a full factory reset - since the old schedules are still running.
        Hi Mark... I did a Network/Interface reset and everything still works... I've transition to HomeSeer and your Plugin... which work GREAT!!! My issue is with the IP address of the Insteon Hub now... it is outside my static map set up in the router. I can adjust my routers map (sort of a pain given where the IP address of the Hub currently is) but I was hoping for a way to change the IP address of the Insteon Hub. Didn't the version 1 hubs have that capability outside of the web interface... something like //<ip address of hubort>/network.cfg or something like that??
          yah , i think that network page is gone. i tried to look for it.
          i would recommend making an ip reservation in your dhcp server even if you have to rearrange your dhcp pool and other mappings
          Mark
          HS3 Pro 3.0.0.534
            Originally posted by warren@wcnjsmith.com View Post
            No, just soft reset.
            what is a soft reset?
            Mark
            HS3 Pro 3.0.0.534
              When we finally determine a factory reset is safe, here is the process
              Factory Reset Insteon Hub (2014)
              1. Disconnect Insteon Hub from power
              2. Press and hold the set button while reconnecting power. Insteon Hub will emit a long beep.
              3. When the long beep ends, release the set button. Insteon Hub will double-beep and after 30 seconds, Insteon Hub will beep again.
              4. Power cycle Insteon Hub by disconnecting and then reconnecting it to power.
              Mark
              HS3 Pro 3.0.0.534
                Here is the problem I'm having with the Hub and the IP address... it keeps changing? I've reset the DHCP lease time to 2 days but for some reason the Hub just changed it's IP address again... which of course means I need to go into Homeseer and change the settings to the new address and reboot. Sort of a pain if this continues!
                  Then I would suggest removing the red banner at the top of the forum.
                    I think I got what you were saying... I associated the MAC address of the Hub with a specific IP address in my pool. So if I understand that correctly if the Hub loses power it should get that IP address back from the router no matter what.
                      which banner. you can close them with the X
                      Mark
                      HS3 Pro 3.0.0.534
                        that is correct
                        Mark
                        HS3 Pro 3.0.0.534
                          Right, but it does come on by default, so may be confusing for new followers.
                            just to be clear, you are suggesting removing the banner about not resetting the hub?
                            i saw a second banner recently
                            Mark
                            HS3 Pro 3.0.0.534
                              Can anyone confirm that doing a reset via the plugin clears the internal hub schedules leftover from the insteon app?
                              Mark
                              HS3 Pro 3.0.0.534
