Well from the school of if you beat it to death, go ahead hit it again.... I had done 2 factory resets on my Hub shortly after Insteon went south - and I can vouch for the fact that in my case the Hub still works and Mark's plug is connected and works. Adding devices now. I also happened to have a brand new out of the box backup hub laying around that had never been deployed - it connected fine as well. It is good to have a plan and a backup....
Did You Perform a Factory Reset On Your Insteon Hub?
Originally posted by 2BossDogs View PostWell from the school of if you beat it to death, go ahead hit it again.... I had done 2 factory resets on my Hub shortly after Insteon went south - and I can vouch for the fact that in my case the Hub still works and Mark's plug is connected and works. Adding devices now. I also happened to have a brand new out of the box backup hub laying around that had never been deployed - it connected fine as well. It is good to have a plan and a backup....
are there any schedules still running from the hub?Mark
HS3 Pro 3.0.0.534
Originally posted by mnsandler View PostCan anyone confirm that doing a reset via the plugin clears the internal hub schedules leftover from the insteon app?
Originally posted by Gadgets View Post
I tried one of the reset options via the plugin, but I'm a work right now and don't remember which one... I kind of guessed. LOL Original schedules are still running. Which plugin option should I use and I will report back tonight.Mark
HS3 Pro 3.0.0.534
just to be clear, you are suggesting removing the banner about not resetting the hub?
i saw a second banner recently
It had a red background with yellow characters I believe.
But Mark, seeing the hours you're putting in to these forums lately, don't give did a high priority.
Originally posted by claude View Post
Yes, exactly. I wish I could show the banner, but I already 'X'd it.
please run the plugin Interface/reset interface option and report back if the schedules go away
Last edited by Gadgets; April 27, 2022, 07:18 PM. Reason: update: Sunset even ran at 8:16pm like it should
thanks
I did the Insteon Hub Reset and it worked. Just received the new controller yesterday and did the initial setup. Here are the basic setup steps.
Setup the HS4 web app
Added the MNS plugin
Disabled the Z-wave plugin
Set up the Insteon devices and confirmed they worked from the HomeTroller screen
Reset the Insteon hub
Confirmed the devices still worked
Confirmed the old Insteon scenes no longer function
Nest steps are to recreate the events to mimic the old Insteon scenes...
...Al
- Likes 1
Originally posted by pcowley32@gmail.com View PostDid you do a full factory reset on the hub? All cautions thus far say not to do that or it renders the hub useless?? Did it get rid of the schedules in the Insteon Hub?
…Al
Originally posted by jgb View PostDoes anyone know if it is possible to set a static IP on the hub after the reset, or is the only option a DHCP reservation? I believe the static IP config for the hub used to be set via the insteon app.Mark
HS3 Pro 3.0.0.534
Performed a reset via the plugin and NO JOY. Insteon hub schedules still in control. Performed a factory reset and HomeSeer still works. I'll know tonight if the Insteon Hub schedules were successfully cleared.
I have to say that without Mark, the HomeSeer support desk, and this forum I would be SOL, I'm not that techie, started with X-10 a few decades ago and evolved into Insteon. I could see the whole thing gradually going down hill, but I kept grinding away because of the cost to scrap all the hardware. My bad!
UPDATE; Factory reset of the Insteon hub worked. It's been a couple of days. Old Insteon schedules are deleted and HS4 running on the HTPlus hub is now in control.
Life is good once again!
- Likes 1
