6 button keypadlinc
    #16
    I've posted the logs below from the point I enabled detailed logging forward. From the web UI I attempted to use button C on the kpl to first turn on the two devices, and then turn them back off. Only the lamp module responded to the on/off commands - the wall outlet did not turn on or off.
    4/30/2022 11:17:22 AM Insteon Info Setting status and value for device 2E.AF.19:1. Old status:100 Old Value:100, New Status:3 New Value:0
    4/30/2022 11:17:22 AM Insteon Info Received a Direct ACK from Living Room LR Lamp (2E.AF.19): 2E AF 19 54 0F FF 2A 13 00
    4/30/2022 11:17:22 AM Insteon Info ..Got Hub Response 02 62 2E AF 19 0A 13 00 06
    4/30/2022 11:17:22 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):2E AF 19 54 0F FF 2A 13 00
    4/30/2022 11:17:22 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:17:22 AM Insteon Info ..My XML buffer: 02622EAF190A13000602502EAF19540FFF2A1300
    4/30/2022 11:17:20 AM Insteon Info Sending http://192.168.1.55:25105/3?02622EAF190A1300=I=3
    4/30/2022 11:17:20 AM Insteon Info Sending command 02 62 2E AF 19 0A 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:17:20 AM Insteon Info Setting status and value for device 50.5D.6F:1. Old status:100 Old Value:100, New Status:3 New Value:0
    4/30/2022 11:17:20 AM Insteon Info Received a Direct ACK from Living Room LR Outlet (50.5D.6F): 50 5D 6F 54 0F FF 2A 13 00
    4/30/2022 11:17:20 AM Insteon Info ..Got Hub Response 02 62 50 5D 6F 0A 13 00 06
    4/30/2022 11:17:20 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):50 5D 6F 54 0F FF 2A 13 00
    4/30/2022 11:17:20 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:17:20 AM Insteon Info ..My XML buffer: 0262505D6F0A1300060250505D6F540FFF2A1300
    4/30/2022 11:17:18 AM Insteon Info Sending http://192.168.1.55:25105/3?0262505D6F0A1300=I=3
    4/30/2022 11:17:18 AM Insteon Info Sending command 02 62 50 5D 6F 0A 13 00 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:17:18 AM Insteon Info Received a Direct ACK from Hallway Hallway Keypad (58.30.61): 58 30 61 54 0F FF 2A 2E 00
    4/30/2022 11:17:18 AM Insteon Info ..Got Hub Response 02 62 58 30 61 1A 2E 00 00 09 C0 00 00 00 00 00 00 00 00 00 00 09 06
    4/30/2022 11:17:18 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):58 30 61 54 0F FF 2A 2E 00
    4/30/2022 11:17:18 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:17:18 AM Insteon Info ..My XML buffer: 02625830611A2E000009C00000000000000000000009060250583061540F FF2A2E00
    4/30/2022 11:17:16 AM Insteon Info Sending http://192.168.1.55:25105/3?02625830611A2E000009C00000000000000000000009=I=3
    4/30/2022 11:17:16 AM Insteon Info Sending sync command 19 to linked responder device: Living Room LR Lamp (2E.AF.19)
    4/30/2022 11:17:16 AM Insteon Info Sending sync command 19 to linked responder device: Living Room LR Outlet (50.5D.6F)
    4/30/2022 11:17:16 AM Insteon Info SyncResponderDevices called for device code: 58.30.61:5
    4/30/2022 11:17:16 AM Insteon Info Sending command 02 62 58 30 61 1A 2E 00 00 09 C0 00 00 00 00 00 00 00 00 00 00 09 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:17:16 AM Insteon Info Checking for keypadlinc button sync on device 58.30.61 src index 5, SrcIsSyncTarget=True...
    4/30/2022 11:17:16 AM Insteon Info Setting status and value for device 58.30.61:5. Old status:100 Old Value:100, New Status:3 New Value:0
    4/30/2022 11:17:16 AM Insteon Info Received a Direct ACK from Hallway Hallway Keypad (58.30.61): 58 30 61 54 0F FF 2A 64 D0
    4/30/2022 11:17:16 AM Insteon Info ..Got Hub Response 02 62 58 30 61 0A 19 01 06
    4/30/2022 11:17:16 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):58 30 61 54 0F FF 2A 64 D0
    4/30/2022 11:17:16 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:17:16 AM Insteon Info ..My XML buffer: 02625830610A1901060250583061540FFF2A64D0
    4/30/2022 11:17:15 AM Insteon Info Sending http://192.168.1.55:25105/3?02625830610A1901=I=3
    4/30/2022 11:17:15 AM Insteon Info Sending command 02 62 58 30 61 0A 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:17:15 AM Insteon Info Attempting to get a KPL LED status response from Insteon device 58.30.61
    4/30/2022 11:17:15 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to Off (102) by/from: CAPI Control Handler
    4/30/2022 11:17:12 AM HomeSeer Web Server Web Server authorized login successful from: 192.168.1.100 User: <removed>
    4/30/2022 11:16:54 AM Insteon Info Setting status and value for device 2E.AF.19:1. Old status:0 Old Value:0, New Status:2 New Value:100
    4/30/2022 11:16:54 AM Insteon Info Received a Direct ACK from Living Room LR Lamp (2E.AF.19): 2E AF 19 54 0F FF 2A 34 FF
    4/30/2022 11:16:54 AM Insteon Info ..Got Hub Response 02 62 2E AF 19 0A 34 FF 06
    4/30/2022 11:16:54 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):2E AF 19 54 0F FF 2A 34 FF
    4/30/2022 11:16:54 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:16:54 AM Insteon Info ..My XML buffer: 02622EAF190A34FF0602502EAF19540FFF2A34FF
    4/30/2022 11:16:52 AM Insteon Info Sending http://192.168.1.55:25105/3?02622EAF190A34FF=I=3
    4/30/2022 11:16:52 AM Insteon Info Sending command 02 62 2E AF 19 0A 34 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:16:52 AM Insteon Info Setting status and value for device 50.5D.6F:1. Old status:0 Old Value:0, New Status:2 New Value:100
    4/30/2022 11:16:52 AM Insteon Info Received a Direct ACK from Living Room LR Outlet (50.5D.6F): 50 5D 6F 54 0F FF 2A 2E FF
    4/30/2022 11:16:52 AM Insteon Info ..Got Hub Response 02 62 50 5D 6F 0A 2E FF 06
    4/30/2022 11:16:52 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):50 5D 6F 54 0F FF 2A 2E FF
    4/30/2022 11:16:52 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:16:52 AM Insteon Info ..My XML buffer: 0262505D6F0A2EFF060250505D6F540FFF2A2EFF
    4/30/2022 11:16:50 AM Insteon Info Sending http://192.168.1.55:25105/3?0262505D6F0A2EFF=I=3
    4/30/2022 11:16:50 AM Insteon Info Sending command 02 62 50 5D 6F 0A 2E FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:16:50 AM Insteon Info Received a Direct ACK from Hallway Hallway Keypad (58.30.61): 58 30 61 54 0F FF 2A 2E 00
    4/30/2022 11:16:50 AM Insteon Info ..Got Hub Response 02 62 58 30 61 1A 2E 00 00 09 D0 00 00 00 00 00 00 00 00 00 00 F9 06
    4/30/2022 11:16:50 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):58 30 61 54 0F FF 2A 2E 00
    4/30/2022 11:16:50 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:16:50 AM Insteon Info ..My XML buffer: 02625830611A2E000009D000000000000000000000F9060250583061540F FF2A2E00
    4/30/2022 11:16:48 AM Insteon Info Sending http://192.168.1.55:25105/3?02625830611A2E000009D000000000000000000000F9=I=3
    4/30/2022 11:16:48 AM Insteon Info Sending sync command 52 to linked responder device: Living Room LR Lamp (2E.AF.19)
    4/30/2022 11:16:48 AM Insteon Info Sending sync command 46 to linked responder device: Living Room LR Outlet (50.5D.6F)
    4/30/2022 11:16:48 AM Insteon Info SyncResponderDevices called for device code: 58.30.61:5
    4/30/2022 11:16:48 AM Insteon Info Sending command 02 62 58 30 61 1A 2E 00 00 09 D0 00 00 00 00 00 00 00 00 00 00 F9 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:16:48 AM Insteon Info Checking for keypadlinc button sync on device 58.30.61 src index 5, SrcIsSyncTarget=True...
    4/30/2022 11:16:48 AM Insteon Info Setting status and value for device 58.30.61:5. Old status:0 Old Value:0, New Status:2 New Value:100
    4/30/2022 11:16:48 AM Insteon Info Received a Direct ACK from Hallway Hallway Keypad (58.30.61): 58 30 61 54 0F FF 2A 64 C0
    4/30/2022 11:16:48 AM Insteon Info ..Got Hub Response 02 62 58 30 61 0A 19 01 06
    4/30/2022 11:16:48 AM Insteon Info Received STX 0x50 (Raw Insteon Rec):58 30 61 54 0F FF 2A 64 C0
    4/30/2022 11:16:48 AM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
    4/30/2022 11:16:48 AM Insteon Info ..My XML buffer: 02625830610A1901060250583061540FFF2A64C0
    4/30/2022 11:16:48 AM HomeSeer Web Server Web Server authorized login successful from: 192.168.1.252 User: <removed>
    4/30/2022 11:16:47 AM Insteon Info Sending http://192.168.1.55:25105/3?02625830610A1901=I=3
    4/30/2022 11:16:47 AM Insteon Info Sending command 02 62 58 30 61 0A 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    4/30/2022 11:16:47 AM Insteon Info Attempting to get a KPL LED status response from Insteon device 58.30.61
    4/30/2022 11:16:47 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to On (101) by/from: CAPI Control Handler
    4/30/2022 11:16:43 AM HomeSeer Web Server Web Server authorized login successful from: 192.168.1.252 User: <removed>
    4/30/2022 11:16:43 AM HomeSeer Web Server Web Server authorized login successful from: 192.168.1.100 User: <removed>
    4/30/2022 11:16:17 AM HomeSeer Web Server Web Server authorized login successful from: 192.168.1.252 User: <removed>
    4/30/2022 11:16:06 AM Insteon Info Saved ini file. msecs=4
    4/30/2022 11:15:56 AM Insteon Info Logging level changed to Detailed
      #17
      if i parse out the readable entries for you, you can see the plugin sends commands to both devices and they sent an ACK, and then the plugin updated the hs ui status. Not sure why the actual device didn't turn off.
      4/30/2022 11:17:22 AM Insteon Info Received a Direct [B]ACK [/B]from Living Room LR Lamp (2E.AF.19): 2E AF 19 54 0F FF 2A 13 00
      4/30/2022 11:17:20 AM Insteon Info Received a Direct [B]ACK [/B]from Living Room LR Outlet (50.5D.6F): 50 5D 6F 54 0F FF 2A 13 00
      everything looks like it worked correctly
      i suppose you could factory reset the device that isn't working correctly and rebuild the links. you do not need to delete the device from the plugin
      factor reset the device, run program device for homeseer, and then rebuild the links from the kpl C btn.
      Mark
      HS3 Pro 3.0.0.534
        #18
        So strange. I tried the factory rest followed by programming the reset device for homeseer. When I rebuild the links, only the device I create first responds - I can make the button control the lamp module by adding it before the outlet, or I can delete both links and add the outlet first and then it will respond to HS4 UI button C presses. Button C on the kpl itself continues to function properly no matter which order I create the links in. The individual device controls in HS4 work instantly, and the group I made for the room also performs correctly. I'm going to try factory resetting the kpl next, but as you've indicated it already appears to be sending the correct commands. A real head scratcher.
          #19
          Bump... would you mind taking another quick look at this please? I've finally registered HS4 and the plugin, but this one final issue is preventing me from being 100%. Button C on my 6 button kpl controls 2 devices. The button on the keypad itself works fine, but if I try to control it via HS4 (standard or mobile) it only controls 1 of the 2 devices.
          I do have sync linked responders enabled and the A,B & D (controls 2 devices like button c) all work fine
          Here's the logs. The 'Info' type controls are from the kpl itself and successful. The 'Device Control' type are from HS4 and only controls 1 of 2 devices.
            #20
            can you capture the hs log using the following like i did in post # 17 above
            To post an HS log if you have issues or get errors (Do not copy and post the log, its unreadable)
            - Goto to the hs tools/log menu, Export the log of the transactions, download it and attach it to your post
            can you verify the default on-level for the switch that wont come on? it might be set to zero
            see the Insteon tab from the hs devices page
            Mark
            HS3 Pro 3.0.0.534
              #21
              I think you are right on the default on-level (see link no 1 - on level @ 0%). How can I change that?
              Click image for larger version  Name:	hs4_device_C.jpg Views:	0 Size:	34.5 KB ID:	1547331
              5/22/2022 11:50:49 AM Insteon Info Received Hallway Hallway Keypad - Button On/Load Button On/Load: (58.30.61) Go OFF
              5/22/2022 11:50:15 AM Insteon Info Received Hallway Hallway Keypad - Button On/Load Button On/Load: (58.30.61) Go ON
              5/22/2022 10:55:51 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to Off (102) by/from: CAPI Control Handler
              5/22/2022 10:55:27 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to On (101) by/from: CAPI Control Handler
              5/22/2022 10:55:12 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to On (101) by/from: CAPI Control Handler
              5/22/2022 10:55:05 AM Insteon Info Received Hallway Living Room Lights - Button C Button C: Living Room Lights - Button C (58.30.61) Go OFF
              5/22/2022 10:54:59 AM Insteon Info Received Hallway Living Room Lights - Button C Button C: Living Room Lights - Button C (58.30.61) Go ON
              5/22/2022 10:49:37 AM Insteon Info Received Hallway Living Room Lights - Button C Button C: Living Room Lights - Button C (58.30.61) Go OFF
              5/22/2022 10:48:57 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to On (101) by/from: CAPI Control Handler
              5/22/2022 10:35:12 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Kitchen Lights - Button A to On (101) by/from: CAPI Control Handler
              5/22/2022 10:35:04 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Media Room Lights - Button B to Off (102) by/from: CAPI Control Handler
              5/22/2022 10:34:56 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to Off (102) by/from: CAPI Control Handler
              5/22/2022 10:34:48 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Kitchen Lights - Button A to Off (102) by/from: CAPI Control Handler
              5/22/2022 10:34:33 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Dining Room Lights - Button D to Off (102) by/from: CAPI Control Handler
              5/22/2022 10:33:32 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Dining Room Lights - Button D to On (101) by/from: CAPI Control Handler
              5/22/2022 10:33:29 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to On (101) by/from: CAPI Control Handler
              5/22/2022 10:33:22 AM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Media Room Lights - Button B to On (101) by/from: CAPI Control Handler
              5/22/2022 10:31:35 AM HomeSeer Plug-In Finished initializing plug-in MNS Insteon
              5/22/2022 10:31:35 AM HomeSeer Starting Plug-In MNS Insteon loaded in 10428 milliseconds
              5/22/2022 10:31:35 AM HomeSeer Starting Plug-In Plugin MNS Insteon started successfully in 10214 milliseconds
              5/22/2022 10:31:34 AM Insteon Info Registering Advanced settings page
              5/22/2022 10:31:34 AM Insteon Info External Device Registration complete.
              5/22/2022 10:31:34 AM Insteon Info Waiting to initialize External Devices...
              5/22/2022 10:31:34 AM Insteon Info Registering Basic settings page
              5/22/2022 10:31:32 AM Insteon Info Hub contacted on 192.168.1.55:25105 with an Insteon address of 54.0F.FF and firmware version A5
              5/22/2022 10:31:24 AM Insteon Info Insteon Support library (Insteon.dll) version: 1.4.3.0
              5/22/2022 10:31:24 AM HomeSeer Starting Plug-In Initializing plugin MNS Insteon ...
              5/22/2022 10:31:24 AM HomeSeer Info Plugin Insteon with instance MNS Insteon has connected. IP:127.0.0.1:60142
                #22
                set the default on level from the Insteon tab on the hs device page. please check your other dimmers while you are at it,.
Name:	switchlinc insteon tab.png
                Mark
                HS3 Pro 3.0.0.534
                  #23
                  I did, however, just realize that the other device connected to button C - and works from HS4 - has essentially the same programming as the device that does not respond.
                  Working device connected to button C:
                    #24
                    Just saw your previous post. When I went to the area you indicate the Led brightness was set to 52 and the default on level was unset. I changed the Led level to 0-lowest and the default on level to 100% and saved. Button C from HS4 continues to only control the 1 device
                      #25
                      please enable detailed logging on the plugin settings. then turn the c button On, and capture the log of what happens next
                      please dont click the c button off, its too confusing to read the log
                      i need see from the device control (of the c button) to a several seconds afterwards
                      Mark
                      HS3 Pro 3.0.0.534
                        #26
                        Here's the detailed log output:
                        5/22/2022 5:19:26 PM Insteon Info Setting status and value for device 2E.AF.19:1. Old status:100 Old Value:100, New Status:2 New Value:100
                        5/22/2022 5:19:26 PM Insteon Info Received a Direct ACK from Living Room LR Lamp (2E.AF.19): 2E AF 19 54 0F FF 2A 34 FF
                        5/22/2022 5:19:26 PM Insteon Info ..Got Hub Response 02 62 2E AF 19 0A 34 FF 06
                        5/22/2022 5:19:26 PM Insteon Info Received STX 0x50 (Raw Insteon Rec):2E AF 19 54 0F FF 2A 34 FF
                        5/22/2022 5:19:26 PM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
                        5/22/2022 5:19:26 PM Insteon Info ..My XML buffer: 02622EAF190A34FF0602502EAF19540FFF2A34FF
                        5/22/2022 5:19:24 PM Insteon Info Sending http://192.168.1.55:25105/3?02622EAF190A34FF=I=3
                        5/22/2022 5:19:24 PM Insteon Info Sending command 02 62 2E AF 19 0A 34 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                        5/22/2022 5:19:24 PM Insteon Info Setting status and value for device 50.5D.6F:1. Old status:100 Old Value:100, New Status:2 New Value:100
                        5/22/2022 5:19:24 PM Insteon Info Received a Direct ACK from Living Room LR Outlet (50.5D.6F): 50 5D 6F 54 0F FF 2A 2E FF
                        5/22/2022 5:19:24 PM Insteon Info ..Got Hub Response 02 62 50 5D 6F 0A 2E FF 06
                        5/22/2022 5:19:24 PM Insteon Info Received STX 0x50 (Raw Insteon Rec):50 5D 6F 54 0F FF 2A 2E FF
                        5/22/2022 5:19:24 PM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
                        5/22/2022 5:19:24 PM Insteon Info ..My XML buffer: 0262505D6F0A2EFF060250505D6F540FFF2A2EFF
                        5/22/2022 5:19:22 PM Insteon Info Sending http://192.168.1.55:25105/3?0262505D6F0A2EFF=I=3
                        5/22/2022 5:19:22 PM Insteon Info Received a Direct ACK from Hallway Hallway Keypad (58.30.61): 58 30 61 54 0F FF 2A 2E 00
                        5/22/2022 5:19:22 PM Insteon Info Sending command 02 62 50 5D 6F 0A 2E FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                        5/22/2022 5:19:22 PM Insteon Info ..Got Hub Response 02 62 58 30 61 1A 2E 00 00 09 D0 00 00 00 00 00 00 00 00 00 00 F9 06
                        5/22/2022 5:19:22 PM Insteon Info Received STX 0x50 (Raw Insteon Rec):58 30 61 54 0F FF 2A 2E 00
                        5/22/2022 5:19:22 PM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
                        5/22/2022 5:19:22 PM Insteon Info ..My XML buffer: 02625830611A2E000009D000000000000000000000F9060250583061540F FF2A2E00
                        5/22/2022 5:19:20 PM Insteon Info Sending http://192.168.1.55:25105/3?02625830611A2E000009D000000000000000000000F9=I=3
                        5/22/2022 5:19:20 PM Insteon Info Sending sync command 52 to linked responder device: Living Room LR Lamp (2E.AF.19)
                        5/22/2022 5:19:20 PM Insteon Info Sending sync command 46 to linked responder device: Living Room LR Outlet (50.5D.6F)
                        5/22/2022 5:19:20 PM Insteon Info SyncResponderDevices called for device code: 58.30.61:5
                        5/22/2022 5:19:20 PM Insteon Info Sending command 02 62 58 30 61 1A 2E 00 00 09 D0 00 00 00 00 00 00 00 00 00 00 F9 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                        5/22/2022 5:19:20 PM Insteon Info Checking for keypadlinc button sync on device 58.30.61 src index 5, SrcIsSyncTarget=True...
                        5/22/2022 5:19:20 PM Insteon Info Setting status and value for device 58.30.61:5. Old status:100 Old Value:100, New Status:2 New Value:100
                        5/22/2022 5:19:20 PM Insteon Info Received a Direct ACK from Hallway Hallway Keypad (58.30.61): 58 30 61 54 0F FF 2A 66 C0
                        5/22/2022 5:19:20 PM Insteon Info ..Got Hub Response 02 62 58 30 61 0A 19 01 06
                        5/22/2022 5:19:20 PM Insteon Info Received STX 0x50 (Raw Insteon Rec):58 30 61 54 0F FF 2A 66 C0
                        5/22/2022 5:19:20 PM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
                        5/22/2022 5:19:20 PM Insteon Info ..My XML buffer: 02625830610A1901060250583061540FFF2A66C0
                        5/22/2022 5:19:18 PM Insteon Info Sending http://192.168.1.55:25105/3?02625830610A1901=I=3
                        5/22/2022 5:19:18 PM Insteon Info Received a Direct ACK from Hallway Hallway Keypad (58.30.61): 58 30 61 54 0F FF 2A 66 C0
                        5/22/2022 5:19:18 PM Insteon Info ..Retry [NODE="2"]Forum[/NODE] required. Pausing 300ms for Hub to clear...
                        5/22/2022 5:19:18 PM Insteon Info ..Got NAK from the Hub for command
                        5/22/2022 5:19:18 PM Insteon Info Received STX 0x50 (Raw Insteon Rec):58 30 61 54 0F FF 2A 66 C0
                        5/22/2022 5:19:18 PM Insteon Info Sending http://192.168.1.55:25105/1?XB=M=1
                        5/22/2022 5:19:18 PM Insteon Info ..My XML buffer: 0250583061540FFF2A66C015151515
                        5/22/2022 5:19:17 PM Insteon Info Sending http://192.168.1.55:25105/3?02625830610A1901=I=3
                        5/22/2022 5:19:17 PM Insteon Info ..Retry [NODE="1"]Home[/NODE] required. Pausing 250ms for Hub to clear...
                        5/22/2022 5:19:17 PM Insteon Info ..Got junk instead of ACK/NAK for command 02 62 44 0F 71 05 19 00 06
                        5/22/2022 5:19:17 PM Insteon Info Sending command 02 62 58 30 61 0A 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
                        5/22/2022 5:19:17 PM Insteon Info Attempting to get a KPL LED status response from Insteon device 58.30.61
                        5/22/2022 5:19:17 PM HomeSeer Device Control Device: Downstairs Hallway Hallway Keypad - Root Living Room Lights - Button C to On (101) by/from: CAPI Control Handler
                        5/22/2022 5:19:06 PM Insteon Info Saved ini file. msecs=4
                        5/22/2022 5:18:56 PM Insteon Info Logging level changed to Detailed
                          #27
                          thanks for posting
                          I will have test this functionality between a kpl button and an outlet
                          is this the newer two outlet (on/off) device, or the older single dimmer lamp outlet?
                          Mark
                          HS3 Pro 3.0.0.534
                            #28
                            thanks for posting
                            Thank you for taking the time to look into this. I believe it is the older style. Only one outlet is controlled. It's designed only for lamps as it's dimmable, and uses the little magnetic key. Looks like the official designation is: Dual-Band OutletLinc Dimmer (0121) with Firmware 44
                              #29
                              i just tested an A button from a 6btn KPL to my outletlinc. seems to work. this is what i see in the hs log when i have debug set on the plugin Settings page. i think we already saw this in your logs as well.
                              5/23/2022 10:46:08 AM Insteon Info Sending sync command 46 to linked responder device: Desk3 Desk Lamp (17.69.EE)
                              5/23/2022 10:46:08 AM Insteon Info SyncResponderDevices called for device code: 58.91.D6:3
                              5/23/2022 10:46:07 AM HomeSeer Device Control Device: Desk3 Insteon New 6Btn KPL - Root New 6Btn KPL - Button A to On (101) by/from: CAPI Control Handler
                              my outletlinc devices are rather old, and probably has beta firmware, but it works
                              Dual-Band OutletLinc Dimmer (0121) with Firmware B0
                              can you post a pic of the entire MNS insteon tab for the outletlinc similar to the pic i posted in # 22 above
                              Mark
                              HS3 Pro 3.0.0.534
                                #30
                                Thank you for taking the time to test. Here's the requested screenshot:
