to summarize, you can control the outlet via the physical kpl button, and you can control the outlet via the hs ui outlet device (not the kpl btn device), correct?
what about when you press the button on the outletlnc. does the light come on at 100%?
what about if you poll the outlet after pressing the kpl button on the hs ui? from the hs ui page, click the "A" icon
what is the status? does it change
i'm running out of ideas
