Random lights turning on...solved
This topic is closed.
    #16
    Yes, indeed multiple times on reset and interface update.
    Any ideas why this command would get transmitted from the plugin. No events triggered (only have 3 set up) , no groups set up. Only happened once yesterday and that was when the devices turned on at the random time.
    What is SetIOMulti and TransmitGroupMsg ? When would these commands be sent and under what conditions.
    Many thanks,
    Warren
    5/22/2022 09:52:40
    Insteon
    Info
    TransmitGroupMsg called for device code: Group:254, Hub Group 254
    5/22/2022 09:52:39
    Insteon
    Info
    5/22/2022 09:52:39
    Insteon
    Info
    Processing SetIOMulti for Insteon Group - Group Controller Cmd: 0
    5/22/2022 09:52:38
    Insteon
    Info
      #17
      SetIOMulti is what HS4 uses to control insteon devices. the plugin does not call that itself
      something from hs (mobile app, alexa, hs event, etc) is calling the plugin
      Mark
      HS3 Pro 4.2.19.5
        #18
        SOLVED the problem. I was polling my 30+ devices at the rate of 1 second each - apparently just totally overloading the communications within the plugin and HS4. HS$ apparently became confused once in awhile and there the 'lets turn on group 254" message.
        Since turning off polling - no odd issued with group 254 being activated. Response time is much better too.
        Thank you and plugin working just great now.
          #19
          thanks for reporting back. glad you fixed it.
          Mark
          HS3 Pro 4.2.19.5
