Cannot Get Fanlinc to Work - Control Multiple Devices at Once Very Sluggish
    Hello Mark, I've finally gotten everything up and running and synced with Alexa EXCEPT for the FanLinc. FanLinc is recognized as Fan and Light in HomeSeer, and I am able to turn light On and Off in HomeSeer (and Alexa), but the Fan does not work...all it does is show me the status without any way to adjust mode (i.e. low, medium, high, off). Any method to fix?
    Also, when I control any one light at a time (i.e. one command at a time), HomeSeer/Insteon/Alexa is almost instantaneous with its response. However, if I make a group command, it is soooooo slow to respond, with 2-5 seconds of delay in between each light in the group from responding. What could be causing this and how do we improve it? Thanks!
    I need to work on the fanlinc in the plugin. i dont know what the magic combination of settings with the plugin are in order to get it to work with alexa.
    for now, you could create 4 Groups to control the fan at the different levels and then let alexa discover those groups
    Mark
    HS3 Pro 3.0.0.534
      Thanks. What about the long delay when there are multiple devices in a group triggered to turn on or off? groups used to be nearly instantaneous with Insteon server. Is there something causing large delays for mine or is this something everyone experiences with your plug in and HomeSeer? Thanks!
        Are you using a plugin Group? That should Be fast. A single cmd to control several devices at once.
        Look at the hs log. Any errors or delays there’s. Post a log. See the getting started post for details on posting a log.
        Mark
        HS3 Pro 3.0.0.534
          Please see the hs log at the below link. I also included the Insteon Error Log. Very sluggish with multiple switches in a group trying to be controlled. Also, I have now twice in a week experienced the Insteon plugin becoming non-responsive to commands using Alexa and in the Homeseer app directly; Alexa provides feedback that the command went through and the Homeseer app doesn't indicate any connection errors but also does nothing. First time this happened I disabled and reenabled the plugin to make it work. Today, that did not fix it. Thanks!
          Insteon Log: https://drive.google.com/file/d/1rHK...ew?usp=sharing
          HS Log: https://drive.google.com/file/d/1PGK...ew?usp=sharing
            please install the latest beta. i have made changes regarding the disconnect.
            https://forums.homeseer.com/forum/hs...-beta-4-0-3-10
            please post a pic of the event controlling multiple switches.
            Mark
            HS3 Pro 3.0.0.534
