Here's a pretty simple method for determining the IP address of your Insteon plugin using a Windows PC. Follow these steps:
Note that Advanced IP Scanner itself is not directly supported by HomeSeer nor by Mark Sandler. It's simply provided here as a resource for those who do not have direct access to their router DHCP tables.
- Download Advanced IP Scanner to your PC
- Install and run Advanced IP Scanner
- Click the Scan button and look for and entry that shows Smarthome or Smartlabs, Inc. as the manufacturer. This will display the IP address of the Insteon hub. In the example below, the IP address is 192.168.1.65. This will be the IP address to use when configuring the MNS Insteon software plugin.
