Trouble installing Insteon Plugin...solved
New issue -- 400+ links downloaded. Then this in log:
5/18/2022 10:55:53 PM
Insteon
Info
Process Insteon Trigger: system not fully initialized yet...exiting
5/18/2022 10:51:47 PM
Insteon
Info
5/18/2022 10:35:35 PM
Insteon
Info
*** To request help with this problem, please download (from the Interface page) and post this log file to the forum along with any details of what lead to this problem.
Insteon
Info
*** An error occurred in this plug-in. The details were written to the log file - C:\Program Files (x86)\HomeSeer HS4\html\Insteon\log\Insteon-error-report-log.txt
Insteon
Info
***:Forced Error / log generation
5/18/2022 10:35:26 PM
Insteon
Info
5/18/2022 10:32:35 PM
Insteon
Info
Hub contacted on 192.168.68.125:25105 with an Insteon address of 4C.03.0E and firmware version A5
5/18/2022 10:32:25 PM
Insteon
Info
The Insteon Interface has been shutdown.
5/18/2022 10:32:23 PM
Insteon
Info
5/18/2022 10:32:13 PM
Insteon
Info
The Insteon Interface is already shutdown.
please use the following steps to post a log
To post an HS log if you have issues or get errors (Do not copy and post the log, its unreadable)
- Goto to the hs tools/log menu, Export the log of the transactions, download it and attach it to your post
do you get a login prompt from a browser when you enter http:/192.168.68.125:25105
try power cycling the hub
Had to update HS firmware in controller per Tyler. installed Plug-in. Plug-in cannot contact the Insteon hub. Log attached.
Smarthome is 192.168.68.125 today.
Please help.
1 Photo
make sure you have this users permissions on the hs setup/users page.
or try reentering the pswd on the homeseer Setup page, then try the mobile app login again.
if that doesn't work, please open a ticket with hs support.
Worked perfect. Thank you. Only problem I'm having now is when I add a user, then try to log into the Homeseer Mobile app with that new user login info. I get an error message "please check username and password" but I put in the correct info.
I'm sorry, do you have the link for that reset process. I can't find it.
Originally posted by mffox104 View PostI am new to all of this. I attempted to set up my Hometroller Plus Smart Hub with the MNS Insteon Plugin a couple of weeks ago but due to factory resetting my Insteon Hub i couldn't finish. Now that I found out that factory resetting my Insteon Hub isn't a problem anymore, I went back into my smarthub and tried setting it up again, reinstalling the plug in. I now get that error you see above. I deleted the plug in and I'm still seeing this error message regarding disabling the plugin first. I don't know where to go from here.
disable the plugin from the plugins/manage page, restart hs4 again. then update the plugin to 4.0.3.0 to help avoid old issues
As of 5/12 8am PDT. And, yes, I have restarted HS4 several times. log follows:
5/12/2022 7:36:33 AM HomeSeer~!~Database~!~Opening (Mode=Read Only) up HomeSeer LOG database C:\Program Files (x86)\HomeSeer HS4\Logs\HomeSeerLog.hsd
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Loading Settings
5/12/2022 7:36:33 AM HomeSeer~!~Warning~!~HomeSeer was not shut down successfully the previous time it was started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Settings Loaded.
5/12/2022 7:36:33 AM HomeSeer~!~startup~!~
5/12/2022 7:36:33 AM HomeSeer~!~startup~!~*************************************** *****************************************
5/12/2022 7:36:33 AM HomeSeer~!~startup~!~ HomeSeerVersion 4.2.12.0 Edition: HS4 Pro StartingNow
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Creating Class Objects...
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~COM port classes started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Application interface class started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Web server class started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~E-Mail SEND class started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~E-Mail RECEIVE class started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Plug-In Interface class started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Local voice recognition class started.
5/12/2022 7:36:33 AM HomeSeer~!~Startup~!~Loading configuration file ...
5/12/2022 7:36:34 AM HomeSeer~!~Info~!~Loaded 3 Devices.
5/12/2022 7:36:34 AM HomeSeer~!~Warning~!~Unable to load event groups config file, trying backup
5/12/2022 7:36:34 AM HomeSeer~!~Warning~!~Unable to load events config file, trying backup
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~HomeSeer version is: 4.2.12.0
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~Creating Speaker Client Interface Object...
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~This version of HomeSeer is not registered and is running as a trial, 12 days remaining.
5/12/2022 7:36:34 AM HomeSeer~!~Web Server~!~Local IP address (subnet) is: 192.168.68.139 (255.255.255.0)
5/12/2022 7:36:34 AM HomeSeer~!~Web Server~!~Web Server started on port 80
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~Start automation engine...
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~Initializing Speaker Client Interface
5/12/2022 7:36:34 AM HomeSeer~!~Speech~!~Listening for remote speaker connections on port 10401
5/12/2022 7:36:34 AM HomeSeer~!~Database~!~Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS4\Data\Energy\Energy.hsd
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~Updater services starting...
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~Starting Find service...
5/12/2022 7:36:34 AM HomeSeer~!~Info~!~Remote plug-in API interface started on port 10400
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~Checking for available plug-ins
5/12/2022 7:36:34 AM HomeSeer~!~Plug-In~!~Found plug-in: MNS Insteon, version: 4.0.1.0
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~Initializing Plug-Ins
5/12/2022 7:36:34 AM HomeSeer~!~Info~!~Plugin Insteon with instance MNS Insteon has connected. IP:127.0.0.1:52388
5/12/2022 7:36:34 AM HomeSeer~!~Starting Plug-In~!~Initializing plugin MNS Insteon ...
5/12/2022 7:36:34 AM Insteon~!~Info~!~Insteon Support library (Insteon.dll) version: 1.4.0.38
5/12/2022 7:36:34 AM Insteon~!~Info~!~Registering Basic settings page
5/12/2022 7:36:34 AM Insteon~!~Info~!~Registering Advanced settings page
5/12/2022 7:36:34 AM Insteon~!~Info~!~Please visit the plugin config/setting page, and enter a port (e.g. COM1) then restart HS.
5/12/2022 7:36:34 AM HomeSeer~!~Starting Plug-In~!~Plugin MNS Insteon started successfully in 171 milliseconds
5/12/2022 7:36:34 AM HomeSeer~!~Starting Plug-In~!~MNS Insteon loaded in 433 milliseconds
5/12/2022 7:36:34 AM HomeSeer~!~Plug-In~!~Finished initializing plug-in MNS Insteon
5/12/2022 7:36:34 AM HomeSeer~!~HSTouch Server~!~Server started on port 10200
5/12/2022 7:36:34 AM HomeSeer~!~Startup~!~HStouch server started, waiting for clients to connect.
I check the logs -- it requires 4.2 something - I just built my Pi system today so I needed to update the version the HS4
