Using the how-to instructions, I attempted to login to my Insteon hub from a browser. I reset the hub before trying so I could use the username and password on the bottom of the hub. I got the local IP address form the Advanced IP Scanner. When the browser connected to the hub, I got the login screen. But the username and password did not allow me to log on. Has the hub gone bad?
Insteon hub doesn't allow login...solved
It is unlikely the hub has gone bad -- much more likely is you have a problem with the username and/or password -- the font used on the hub makes it hard to differentiate between Ls and Is and Os and zeros (not to mention lowercase is for those of us with old eyes). I had two of those characters in the username and one in the password -- took a lot of tries to find the right combination. Someone suggested scanning the QR code to get them -- that helped me. Good Luck!
yes, please try a qcode app on your phone to read the info. it will be extremely helpful.Mark
HS3 Pro 4.2.19.5
I used the QR code to get the login and password. There was one ambiguous letter in the password. A lower case L that might have been a 1. I tried both the l and the 1. Neither worked.
On the login screen, I enter the username and password, I press enter, and the hub clears the username and password fields and asks for login info again.
I wondered if it was possible that the username and password did not get set to the factory settings when I reset the hub, so I tried my old login info and that didn't work either.
Also, thanks to both of you for assisting me with my dilemma.
Nice jobMark
HS3 Pro 4.2.19.5
power cycle the insteon hub and retry firstMark
HS3 Pro 4.2.19.5
Originally posted by jengen View PostDo I need to use the ":25105" after the IP address?
see the getting started thread for details
https://forums.homeseer.com/forum/hs...insteon-plugin
Mark
HS3 Pro 4.2.19.5
ok, you have confirmed you can log into the hub with the username pswd. that's good
you can now install/add the plugin from the plugins/add page
then continue with the setup procedure
you may need to power cycle the insteon hub if the plugin wont connect initially
Mark
HS3 Pro 4.2.19.5
Originally posted by jengen View PostI tried logging into the Homeseer hub via remote desktop to load the plugin but it would not work with the new login credentials I had set up. I tried using the credentials on the bottom of the hub but that didn't work either. Is there a way to reset the login or am doing something wrong?
or are you trying to log into the insteon hub?
for the insteon hub: the username and password (on the botom), an upper case eye can look like a lower case L. an Oh looks like a zero. Try different letters until you get it right.
or use a qcode reader app on your phone to help identify the correct letters.Mark
HS3 Pro 4.2.19.5
