Insteon Devices Not Working
    I bought the hub and and MNS insteon plugin a few weeks ago. I installed all the devices and everything was working fine. Last night, I noticed one of the events did not run. I logged in and all of my insteon devices were either "unknown" or the status was incorrect (on when it was off, or off when it was on). I'm not sure what to do. When I log into the homeseer account, it says the MNS Insteon plugin is "okay." Thanks in advance.
    please check the hs log (tools/log) for errors
    please restart the plugin and check to make sure the plugin found the hub. the plugin status isn't a good indication that everything is ok. it just means the plugin is running. i may change that.
    post the hs log if there errors
    To post an HS log if you have issues or get errors (Do not copy and post the log, its unreadable)
    - Goto to the hs tools/log menu, Export the log of the transactions, download it and attach it to your post
    Mark
    HS3 Pro 3.0.0.534
      Have you shut down the plug-in, shut down HS4, rebooted and started each back up again? Recycling systems can help - except for the CIO at a very large insurance company I supported who hit the power button on their IBM Mainframe back in the day.... disk crashes were a real thing
        Attached is the log. I tried to make sure the software was up to date. I have not shut down the HS3 but have rebooted them.
          from your log
          Could not contact Interface on 192.168.1.72:25105
          please verify the hub ip address in your home router. you probably need to make an ip reservation for the hub
          Mark
          HS3 Pro 3.0.0.534
            That is correct. I ended up unplugging the inteon hub and restarting the homeseer hub and it is now working. I'm not sure why this happened though.
              Please download and post the hs log per the instructions if this happens again
              Mark
              HS3 Pro 3.0.0.534
