Insteon Events not working...solved
This topic is closed.
    I installed the Hometroller PI + MNS Insteon plugin. I can control switches (outside lights) manually and have set up several Groups and Events, but nothing happens. Is there something 'special' I need to do to get Events working with my Insteon hub? Will restarting and resetting everything help?
    Can you post a pic of the event definition
    Mark
    HS3 Pro 4.2.19.5
      Sure:
      Doesn't want to let me paste a picture, but text:
      Group Conditions: IF - The time is 15 min before sunset.
      THEN:
      Set Devices:
      Plugin Driveway Switch 1 to On
      Plugin Front Columns Switch 2 to On
      Plugin Front Ceiling Switch 3 to On
      Plugin Backyard Switch 4 to On
      Plugin Back Porch Switch 5 to On
      Action: Control a Device
      After Waiting 0 0 0 0
        instead of controller individual devices, create a plugin group and then control the group, you will get a more consistent response
        Mark
        HS3 Pro 4.2.19.5
          Originally posted by Grunert View Post
          Sure:
          THEN:
          Set Devices:
          Group conditions will apply to every event in the group. That's a "Group" of events, not to be confused with a "Group" of Insteon Devices. Instead you should put your sunset condition directly in the "Trigger" field. Example:
Name:	Screenshot 2022-05-18 224637.png
            for future posts: you must create a jpg or png pic file and then upload it
            Mark
            HS3 Pro 4.2.19.5
              Ok - thanks. I'll try that tonight and let you know.
                Connected remotely to try and set this up. I don't see the same menu/options that you have. For example "Set Device" isn't there, etc.:
                  you just need to select the device from the Add device dropdown, then click the save button to the right.
                  Mark
                  HS3 Pro 4.2.19.5
                    Did that. Tried to turn just one light on at 3 pm - didn't work. Troubleshooting ideas? Reset/restart everything??
                      you should be able to run the event manually by clicking the person icon (top right in my pic) to verify the action works
                      for more help with events see this forum
                      https://forums.homeseer.com/forum/hs...4-event-clinic
Name:	basic event.png
                      Mark
                      HS3 Pro 4.2.19.5
                        I'm going to remove, reinstall, reset, and restart everything - let's see how it goes.
                          if everything else is working, i would just delete the event and start clean
                          Mark
                          HS3 Pro 4.2.19.5
                            Decided to get a fresh start - restarted HomeTroller Pi, deleted events, and created a new 'test' event - to turn an Insteon light switch on - didn't work. Hard to understand - I can turn switched on/off via the webpage and app, but the events don't seen to work. Am I missing something to 'activate' them and get events to run?
                              There is nothing required to get events to run -- paste a screen shot of your event -- when you say it "didn't work", you clicked the running-man icon to run the event immediately?
