Insteon Hub goes unresponsive, plugin fills up log
    The plugin has been working fantastic since I set it up and got the kinks worked out. However, today suddenly things got weird. HS4 was allowing me to send commands but nothing was happening. Checked the log and apparently the hub was no longer responding. The plugin tried to recover gracefully and then decided to restart the plugin. On restart of the plugin it gets into a loop of not being started yet...and spews the same log entry several times per minute and fills up the log. The solution was to unplug the hub and plug it back in. The IP address never changed. Everything is working fine now. Wondering if it is a good idea to make the hub restart periodically to avoid this?
    please use the following to post the log
    To post an HS log if you have issues or get errors (Do not copy and post the log, its unreadable)
    - Goto to the hs tools/log menu, Export the log of the transactions, download it and attach it to your post
    can you also post the hs tools/about info. so can see your setup
    Mark
    HS3 Pro 3.0.0.534
      Sorry about that. I have just learned to narrow the scope of the log and export it.. Here you go. Thanks.
        also, do back from the hs tools/backup menu
        and install the latest beta from the plugins/add page
        https://forums.homeseer.com/forum/hs4-products/hs4-plugins/lighting-primary-technology-plug-ins-aa/mns-insteon-mnsandler/1544051-mns-insteon-beta-4-0-3-9
        Mark
        HS3 Pro 3.0.0.534
