I have added all my insteon devices using the plug in. I can control the individual devices using HS4. Previously, the buttons on my 8 keypad would also control some of those devices, but when I switch on the button (using HS4) the LED behind that button on the keypad lights up, but the device it controls does not switch on.
Should the previous links from my 8 button keypad still work?
This topic is closed.
theoretically all the links should still work. there seems to be a discrepancy between how the links are interpreted for display purposes (between the old app and my plugin)
you might delete one link and recreate it via the plugin and see if it works.Mark
HS3 Pro 3.0.0.534
make sure the "sync linked responder" option is turned on from the hs devices page for the keypad
Mark
HS3 Pro 3.0.0.534
- Likes 1
glad you got it working
thanks for the testimonial.Mark
HS3 Pro 3.0.0.534
