External device fails to register
    I have the EZFlora Irrigation controller in the system, controlled by the EZFlora PI. Last night, I updated HS4 to 4.2.12.0 and the startup log showed the following normal entry:
    5/18/2022 8:48:34 PM Legacy-Plugin Insteon External device name 01.73.95 (Address:01.73.95) has registered as external device #1 (This is the EZFlora device)
    Today, I updated your PI to MNS Insteon version: 4.0.3.0
    Now, the EZFlora external device does not register as such and cannot be accessed. I know this device is not under your control but thought you may be able to lead me in the right direction to fix this. I tried resetting the device, stopping and restarting the EZFlora PI, same with your PI, and restarting HS4 - nothing helped.
    can you post the script you are using? I need to verify what i broken fixing the insteon thermostat plugin
    Mark
    HS3 Pro 3.0.0.534
      Sorry, I missed the response- I'm not running any script. the plugin treats the controller as any other I/O, allowing monitoring of inputs and controlling 8 outputs and/or internal programs within the controller. I can't access the controller until it gets registered. the specifics of the controller are attached. the unit, Smartenit model 5010A, is apparently obsolete so I may have to look for a replacement if all else fails.
        hs3 plugins (ie EZFlora PI) are not compatible with my new HS4 MNS Insteon. HS4 does not allow the two APIs to talk to each other; i can't fix this, and hs wont either (i've asked)
        the EZFlora PI will need to be updated to communicate with my new plugin. We had to do this with the Insteon Thermostat plugin
        hurry4it
        Mark
        HS3 Pro 3.0.0.534
          Thanks Mark! BTW, my thermostat seems to be working fine, so far.
            you are running John's new version 3.0.8.0, correct?
            Mark
            HS3 Pro 3.0.0.534
