Events running even though day condition not satisfied?...solved
This topic is closed.
    #16
    can you please explain what you are trying to accomplish?
    I use the following event logic to get notifications when a door opens
    if device sensor transmits an On
    then send email
    this works
    Mark
    HS3 Pro 3.0.0.534
      #17
      Just trying to get the event to send an email when the door is opened and again when it is closed.
        #18
        are you seeing Received messages in the hs log from the sensors when it opens (on) and closes (off)
        Mark
        HS3 Pro 3.0.0.534
          #19
          Door sensor event appears to be working correctly to send open and close email so let's call this issue resolved. Thanks.
            #20
            excellent. can you post your final event so others can see.
            Mark
            HS3 Pro 3.0.0.534
              #21
              Yes messages appear in the log to confirm the sending of Insteon On and Off and the triggering of emails. I've attached a screenshot of the event I'm using, the event log and the virtual device to permit turning the email messages on and off. The Door Close event is the same as the Open but utilized the Insteon "Off" command from the door sensor to trigger the email.
              [ATTACH]n1547629[/ATTACH]
Name:	Screenshot 2022-05-23 at 16-24-11 Devices.png
Name:	Screenshot 2022-05-23 at 16-23-30 Event.png
                #22
                thanks for sharing
                Mark
                HS3 Pro 3.0.0.534
