My Insteon Hub is confirmed and recognized by HS4 and I got 70 devices on a list, but none of them would insert into the plugin device section. Also, the downloaded list gave 12 digits while the device download list only allowed for 6 digits. I actually should have only 20 devices on the hub.
My HS 4 plugin will not accept my devices after I retrieved the list of devices
Mark
HS3 Pro 4.2.19.5
from the hs devices page, control each device one by one to determine its physical location and the update the deviceMark
HS3 Pro 4.2.19.5
can you please elaborate on the type of devices
the control page is the HS Devices page. all insteon devices will show there with controls and statusMark
HS3 Pro 4.2.19.5
screen shot of some switches..I have 2 lamp switches and all the rest are as the enclosed....When I hit the Device 1 Locations Device 1 Name, it does not let me turn on or off that device.Device 1 Location Device 1 Name 4A.0C.39 Dual-Band SwitchLinc Dimmer 45 1 i2CS 96% (19 failed out of 455 cmds) 453 0 0 Excellent Device 10 Location Device 10 Name 48.B7.6C Dual-Band SwitchLinc Dimmer 45 0 i2CS (Not enough data) 0 0 0 No Data
so if you go to the hs devices page, you should see these devices listed with on/off and a dimmer. something like this in list view vs grid view.
Mark
HS3 Pro 4.2.19.5
So I located my library light switch code being looking at the Insteon label on the switch since and put it in. It has at least 3 link data and it shows as per enclosed. But the on-off and dimmer switches do not respond and I have added the info under the Plug in add device a couple of times...I tried the same thing with a lamp switch with no results....
Plugin | Insteon
- Root
Plugin | Insteon
- Root
Plugin | Insteon
- Root
Plugin | Library
Library Lights
Library lights
Unknown
ONOFF
Today 6:36:51 PM
Plugin | Insteon
- Root
Plugin | Global Insteon
Insteon Devices
Group Controller
Start Ramp Brighten
once you Add a device on the plugin Devices page, you can edit, the name, location info on the HS Devices page.
do not try to add it again via the plugin.
please post a pic of your devices from the hs devices pageMark
HS3 Pro 4.2.19.5
