Insteon Hub Plugin Issue
    Hello! I’m attempting to resurrect my Insteon Hub. The MNS Insteon plugin is successfully installed. My HomeTroller Plus has been updated. I can manually access my Insteon Hub. I’ve never unplugged, rebooted or done anything with my Insteon Hub since they went out of business. After successfully installing the MNS Insteon plugin, I went to Settings and typed in the same port info and user/pswd (on the bottom of the hub) that I used to manually connect to the Insteon Hub, but it isn’t finding it. The message on the Settings page states “Warning: Cannot contact the Insteon Interface on 192.168.x.xx:25105. Please check the Settings page.” The IP address is correctly displayed, I just omitted it for this post.
    Any ideas where to go from here? I’m stumped. Please advise. Thank you!
    JollyViking
    Hello and welcome
    sounds like you successfully complete Step 0 on the getting started.
    👉 READ THIS FIRST: Getting started with the MNS Insteon plugin - HomeSeer Message Board
    you may need to power cycle the hub before the plugin can access
    Mark
    HS3 Pro 3.0.0.534
      Thank you. Do you mean power cycle the HomeSeer hub or my Insteon hub?
        insteon hub
        Mark
        HS3 Pro 3.0.0.534
