Just tried msachs9393 recommendation and the devices are finally showing up. It's an odd fix but it works. Thanks!
Adding devices to mobile app...solved.
This topic is closed.
Originally posted by MzRusso View PostJust tried msachs9393 recommendation and the devices are finally showing up. It's an odd fix but it works. Thanks!
Glad to hear it!
@acousticmood@yahoo, you mentioned the same problem, try and see if that "re-enter the password" solution that HS Support suggested works for you also. If it seems to be a consistent fix for enough people then it can continue to be suggested to others who write in the future that they're having this problem without needing to refer them to Support or the Mobile App forums.
that is the end of my knowledge on myhs. please reach out to hs support; the should be able to help outMark
HS3 Pro 4.2.17.0
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3| Ultra1Wire3 | RFXCOM | NetCAM | HS MyQ | BLRadar | BLDenon | Jon00 Charting | Jon00 Links
MzRusso everything good now?Mark
HS3 Pro 4.2.17.0
