Insteon Door Sensors not executing events...solved
This topic is closed.
    #16
    can you put the sensor into linking mode and the run the "read links and settings" from the plugin Devices.
    just need to make sure the sensor has the correct links
    Mark
    HS3 Pro 3.0.0.534
      #17
      I can’t seem to find this function. Can you direct me?
        #18
        just an example of an insteon device page. see the device management section below for the button
        Mark
        HS3 Pro 3.0.0.534
          #19
          It does not appear to be reading the device any longer. I don’t know what happened on May 15th, the last time it saw this device.
            #20
            please backup your system, install the latest beta.
            https://forums.homeseer.com/forum/hs...-beta-4-0-3-10
            put the sensor into linking mode, and run the program device for homeseer on the same plugin page as the read settings
            then retest
            if that doesn't work, delete the sensor from the plugin devices, add it again
            you will need to edit your event to reselect the sensor as the trigger device
            Mark
            HS3 Pro 3.0.0.534
              #21
              Mark, I disabled the plug-in, and installed the beta. I put the device into linking mode and ran the read settings. No luck. So I deleted the device, added it back manually and ran the read settings. Success - “The link table and device settings were successfully retrieved for your device.”
              I edited the event for the new device name I gave it when I readded it manually. I tried to trigger the event by depressing the sensor button (door closed) and releasing it (door open). The event was not triggered and there was no “received” entry in the log file for the action.
              I ran an Interface Link report and this door sensor still shows up by device id but no name attached to it.
              where to next?
                #22
                Check your event to make sure it is triggering on the newly created device, and not still looking at the old deleted device.
                  #23
                  where to next?
                  are there any errors in the hs log when you start the plugin, or perform any plugin functions? if so post them
                  another user got them working, so we should be able to get yours working too
                  Mark
                  HS3 Pro 3.0.0.534
                    #24
                    Here is a snippet from the log when I installed the beta and started it up. The device id is 45 DB C6. Insteon log snippet.pdf
                      #25
                      there are a lot of errors in the log. these be resolved before things are going to work properly.
                      please click the Fix button on the plugin Devices page. then restart the plugin and post the hs log after startup
                      To post an HS log if you have issues or get errors (Do not copy and post the log, its unreadable)
                      - Goto to the hs tools/log menu, Export the log of the transactions, download it and attach it to your post
                      Mark
                      HS3 Pro 3.0.0.534
                        #26
                        Genius! The fix button fixed the issues. No errors on startup. Notifications working. THANK YOU!
                          #27
                          Amazing!
                          Mark
                          HS3 Pro 3.0.0.534
