Unable to find my Insteon Hub
    I have run the IP search on my home network and my Insteon Hub never shows up yet it continues to operate the light schedule.
    power cycle the insteon hub, and run the scanner again. or check in your home router (DHCP/ip reservation function) for an IP address mapped to a mac/physical address that ends with your insteon hub's ID
    Mark
    HS3 Pro 3.0.0.534
      I have tried to power cycle the Insteon hub. Still not there. I don’t know how to log into my router.
        what platform are you running HS4 on?
        Mark
        HS3 Pro 3.0.0.534
          Homeseer Pi.
            Is that what you meant by platform?
              if you look on the hs tools/about page, you will find the ip address of the hometroller Pi.
              i suppose you can try different IPs in that same subnet
              eg if the Pi is on 192.168.1.11, then start trying 192.168.1.1:25105, 192.168.1.2:25105, etc in your browser until get get a login response from the insteon hub
              note the colon between the ip address and the port number 25105
              the alternative is try another ip scanner app maybe your phone
              Mark
              HS3 Pro 3.0.0.534
