I have run the IP search on my home network and my Insteon Hub never shows up yet it continues to operate the light schedule.
Unable to find my Insteon Hub
power cycle the insteon hub, and run the scanner again. or check in your home router (DHCP/ip reservation function) for an IP address mapped to a mac/physical address that ends with your insteon hub's IDMark
HS3 Pro 4.2.19.5
what platform are you running HS4 on?Mark
HS3 Pro 4.2.19.5
if you look on the hs tools/about page, you will find the ip address of the hometroller Pi.
i suppose you can try different IPs in that same subnet
eg if the Pi is on 192.168.1.11, then start trying 192.168.1.1:25105, 192.168.1.2:25105, etc in your browser until get get a login response from the insteon hub
note the colon between the ip address and the port number 25105
the alternative is try another ip scanner app maybe your phoneMark
HS3 Pro 4.2.19.5
