Plugin Installed -- Update Interface Produces Errors...solved
This topic is closed.
    I had resolved trouble before and thought troubles were over when Plug In installed.
    However, it does not work. W10 environment. Hub2 Insteon. HS4 on HT-PLUS-G2
    Error log uploaded. Updating Interface does not produce results, just errors.
    Note -- Prior posting showed problem solved. I spoke too soon. NOT solved. New problem. Please help.
    i do not see any devices registered based on the log you provided
    do you see anything on the plugin Devices page
    do you have a hs backup that you can restore
    Mark
    HS3 Pro 3.0.0.534
      Hi
      I do not see any Devices on Plugin Page. Just the header.
      I do not have any HS Backups. Waiting until I have something to Backup.
      Next steps??
        sounds like you need to Add your devices to the plugin from the Devices/Add Device page
        see step 7 on here
        https://forums.homeseer.com/forum/hs...insteon-plugin
        then this section: To register devices:
        Mark
        HS3 Pro 3.0.0.534
          All is well. Interface working. Turning on lights.
          Is there a way to access the Insteon Hub table of Names & Addresses instead of entering all manually via the Plugin Device Add function? I have 58 devices. Also, same question for scenes -- I have 22.
            i do not have code to read any setup from the insteon hub. all the plugin can do is read the link database which is just isnteon IDs.
            Mark
            HS3 Pro 3.0.0.534
              Can I add devices to a group later? I created the group with 1 device. I need to add 8 more to the group.
                Add your devices, and then create the Groups. you can add devices to a group at any point
                Mark
                HS3 Pro 3.0.0.534
                  I tried a couple of ways. Last try PlugIns/Groups/Checked a group/Add/checked devices/Save Got this error msg:
                  A group with that Name and Location already exists.
                    can you post some pics of what you are doing?
                    editing a group and adding a device should be no problem
                    Mark
                    HS3 Pro 3.0.0.534
                      See attachments
                        click the name of the existing group to edit it
                        Mark
                        HS3 Pro 3.0.0.534
                          Thanks. Works fine now. Not obvious, but now I got it.
                            thanks for reporting back.
                            Mark
                            HS3 Pro 3.0.0.534
