Plugin Installed -- Update Interface Produces Errors...solved
Thanks. Works fine now. Not obvious, but now I got it.
can you post some pics of what you are doing?
editing a group and adding a device should be no problem
I tried a couple of ways. Last try PlugIns/Groups/Checked a group/Add/checked devices/Save Got this error msg:
A group with that Name and Location already exists.
Add your devices, and then create the Groups. you can add devices to a group at any point
Can I add devices to a group later? I created the group with 1 device. I need to add 8 more to the group.
Originally posted by bobasquith@yahoo.com View PostAll is well. Interface working. Turning on lights.
Is there a way to access the Insteon Hub table of Names & Addresses instead of entering all manually via the Plugin Device Add function? I have 58 devices. Also, same question for scenes -- I have 22.
sounds like you need to Add your devices to the plugin from the Devices/Add Device page
see step 7 on here
https://forums.homeseer.com/forum/hs...insteon-plugin
then this section: To register devices:
Hi
I do not see any Devices on Plugin Page. Just the header.
I do not have any HS Backups. Waiting until I have something to Backup.
Next steps??
i do not see any devices registered based on the log you provided
do you see anything on the plugin Devices page
do you have a hs backup that you can restore
I had resolved trouble before and thought troubles were over when Plug In installed.
However, it does not work. W10 environment. Hub2 Insteon. HS4 on HT-PLUS-G2
Error log uploaded. Updating Interface does not produce results, just errors.
Note -- Prior posting showed problem solved. I spoke too soon. NOT solved. New problem. Please help.Attached FilesTags: None
