I had everything working fine since install a week ago and now it can not contact the insteon controller. I double checked ip addresses are the same but I am unable to ping the controller as well. Not sure what I should do or if my hub just died. Cant really tell since always has red light now. Any advice?
Cannot contact insteon controller anymore
did you try power cycling the insteon hub? what else?
if you cant ping the insteon hub, that would lead me to believe the ip addr changed
Mark
HS3 Pro 3.0.0.534
Yes I power cycled both hubs and verified ip address is the same in my router. I did find it strange I could not ping it so was wondering if dead. It did show minimal activity in my router. I am unsure if I should do a factory reset or not. I know I saw somewhere that it wont matter and HS4 will still communicate but still a bit timid to do so.
see below. start with the network reset, then retest. if that doesnt work, do the factor reset. if the plugin starts up, run the interface/update interface routine.
https://forums.homeseer.com/forum/hs...42#post1546542Mark
HS3 Pro 3.0.0.534
