Insteon Motion Sensor Events
This topic is closed.
    I'm trying to use the Insteon Motion Sensor to turn on 2 sets of lights. My event does successfully turn the lights on but they are turned off a minute later then the motion sensor transmits an "off" status. See my event, it does not capture the "off" trigger so I don't understand why the lights go off. In addition the event triggers a plugin error, see the log. Need some help. Thanks.
    log(18).txt insteon-error-report-log(14a).txt insteon-error-report-log(14b).txt
    Click image for larger version  Name:	Screenshot 2022-05-26 at 14-50-30 Event.png Views:	20 Size:	97.1 KB ID:	1548231
    It sounds like you have the motion sensor and light switches linked directly together. That could explain the lights turning off after the 1 minute no motion time out
    HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
    Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Harmony Hub, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
      I'm also showing a message on the Insteon PlugIn Interface for unregistered links for 2 devices which do appear an are controlled on the device page. These 2 lamps are turned on/off by the motion sensor trigger so maybe this message is related. I've attached screen shots.
Name:	Screenshot 2022-05-26 at 15-23-29 Manage Interface.png
Name:	Screenshot 2022-05-26 at 15-24-07 Edit Device.png
        I think link number 8 is turning your lights off. The unregistered device is another device that hasn't been added to HomeSeer yet. I think you can delete links 8 and 5
          Appears we have this resolved. Your assumption was correct, I had linked the lights directly to the motion sensor so my event was actually being ignored. I reset the lights and the motion sensor to remove all the links and then reprogrammed back to the plug-in. Not when motion is sensed the lights will turn on if they are off and if the light value of the sensor is 50% or less. No action is taken when the sensor sends the Off command. The lights will remain on until turned off manually. Thanks for the help you can close this.
            I may have spoke too soon. The events are working fine but an error page is being generated which I've attached. Please advise what the error is. Thanks.
            log(19).txt insteon-error-report-log(15b).txt insteon-error-report-log(15a).txt
              can you post pics of you current events. and comment on the latest links you have between the MS and switch
              also, please find the plugin insteon device, then goto the mns insteon tab and post the contents here as a text file
              Mark
              HS3 Pro 3.0.0.534
                I'm posting what I believe you requested. I don't find an Insteon Plugin Device in my device list and I'm unclear what you mean by MS switch. Thanks.
                [ATTACH]n1548497[/ATTACH] [ATTACH]n1548498[/ATTACH] [ATTACH]n1548499[/ATTACH] Click image for larger version
Name:	Screenshot 2022-05-27 at 17-35-49 Event.png
Name:	Screenshot 2022-05-27 at 17-30-39 Interface Database Links.png
                  why do you include the group controller status as a condition?
                  MS = motion sensor
                  Mark
                  HS3 Pro 3.0.0.534
                    I'm using the Group Controller condition so the lights will only be turned on by the MS if they are off. The Group Controller turns on/off 2 lights in the Den. Should I just use the lights themselves and not the Group Controller? The MS is not directly linked to anything. The Event works as intended except for the error message it continues to generate.
                      enable detailed logging on the plugin settings page, retest your event
                      - Post the HS Log that shows the problem: Goto to the hs tools/log menu, Export the log of the transactions, download it and attach it to your post
                      and is this the error you are referring to?
                      ​​​​​​​5/27/2022 5:29:04 PM Insteon Info ***:Error in DeviceExtraDataString: Object reference not set to an instance of an object. -- Details System.NullReferenceException: Object reference not set to an instance of an object.
                      at HSPI_Insteon.HomeseerAPI.HSAPI.set_DeviceExtraDataString(HsD evice dv, String OptionKey, String value)
                      Mark
                      HS3 Pro 3.0.0.534
                        I've attached the current Tools/Log. Yest the error is essentially the one you've quoted. Thanks.
                        log(20).txt
                          i think i see the problem, its not related to the motion sensor.
                          1. did you enable x10 on the Settings page?
                          2, did you add any X10 devices to the plugin?
                          3. from the hs devices page, find the 'insteon plugin' device, then go to the MNS Insteon tab, and copy and paste the content here
                          Mark
                          HS3 Pro 3.0.0.534
                            Answering your questions: 1. No X10 not enabled on the Insteon Setting page. 2. No - No X10 devices added to the plugin. I've copied the text below of the MNS Insteon Tab:
                            [Config]
                            DetailedLog=1
                            DeviceLocationFilterIndex=0
                            HS3EventsMigrated=1
                            HubPassword=+RhMlt0nYSik8zZSobpecw==
                            HubUsername=Storm662
                            InterfaceCapability=5
                            InterfacePort=192.168.2.142:25105
                            MaxHops=3
                            NumDevices=15
                            NumGroups=1
                            NumInterfaceLinks=56
                            RecreateDevices=0
                            [Device 1]
                            DatabaseDelta=5
                            DeviceID=2F.44.02
                            DeviceLocation=Den
                            DeviceName=Couch Lamp - Right
                            DeviceType=013A
                            EEValues=DefaultOnLevel=254,DefaultRampRate=28,OpFlags1=0
                            FailedInteractions=16
                            FirmwareVer=48
                            HopData=4472,4271,1,200
                            LastContact=5/11/2022 1:42:15 PM
                            Link 1=A2 FE 3B 51 08 FF 1F 01 1
                            Link 2=AA 00 3B 51 08 FF 1C 00 2
                            Link 3=A2 01 3B 51 08 FF 1F 01 3
                            Link 4=A2 01 47 22 51 FF 1F 01 4
                            LinksDownloaded=1
                            NumLinks=4
                            PollingInterval=0
                            Protocol=3
                            RecentDatabaseDelta=5
                            TotalInteractions=370
                            [Device 10]
                            DatabaseDelta=25
                            DeviceID=3A.78.B3
                            DeviceLocation=Kitchen
                            DeviceName=Fan PlugIn
                            DeviceType=010E
                            EEValues=LEDBrightness=0,DefaultOnLevel=254,DefaultRampRate= 28,OpFlags1=96
                            FailedInteractions=14
                            FirmwareVer=43
                            HopData=1967,1630,11,326
                            LastContact=5/20/2022 3:12:37 PM
                            Link 1=E2 01 3B 51 08 03 1C 00 1
                            Link 2=A2 FE 3B 51 08 FF 1F 01 3
                            LinksDownloaded=1
                            NumLinks=2
                            PollingInterval=0
                            Protocol=3
                            RecentDatabaseDelta=25
                            SyncLinkedDevices=0
                            TotalInteractions=66
                            [Device 11]
                            DatabaseDelta=5
                            DeviceID=32.7D.BE
                            DeviceLocation=Garage
                            DeviceName=Garage Door Sensor
                            DeviceType=1011
                            EEValues=HeartbeatInterval=12,LowBatteryLevel=64,OpFlags0=1
                            FailedInteractions=0
                            FirmwareVer=44
                            HopData=2390,2307,50,33
                            LastContact=5/20/2022 4:04:55 PM
                            Link 1=E2 01 3B 51 08 03 00 00 1
                            Link 2=E2 02 3B 51 08 00 00 02 2
                            Link 3=E2 03 3B 51 08 00 00 03 3
                            Link 4=E2 04 3B 51 08 00 00 04 4
                            LinksDownloaded=1
                            NumLinks=4
                            PollingInterval=0
                            Protocol=3
                            SyncLinkedDevices=0
                            TotalInteractions=8
                            [Device 12]
                            DatabaseDelta=4
                            DeviceID=3B.3B.CA
                            DeviceLocation=Main
                            DeviceName=Deck Door Sensor
                            DeviceType=1011
                            EEValues=HeartbeatInterval=0,LowBatteryLevel=64,OpFlags0=1
                            FailedInteractions=30
                            FirmwareVer=45
                            HopData=813,484,1,328
                            LastContact=5/20/2022 4:10:26 PM
                            LinksDownloaded=1
                            NumLinks=4
                            PollingInterval=0
                            Protocol=3
                            RecentDatabaseDelta=4
                            SyncLinkedDevices=0
                            TotalInteractions=54
                            [Device 13]
                            DatabaseDelta=4
                            DeviceID=3A.74.07
                            DeviceLocation=Living Room
                            DeviceName=Living Room Floor Lamp
                            DeviceType=010E
                            FirmwareVer=43
                            HopData=286,286,0,0
                            LastContact=5/27/2022 10:50:24 AM
                            LinksDownloaded=1
                            NumLinks=2
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=44
                            [Device 14]
                            DatabaseDelta=25
                            DeviceID=4A.57.03
                            DeviceName=Living Room Motion Sensor
                            DeviceType=1016
                            EEValues=Mode=0,PIRDelay=3,HeartbeatInterval=62,LowBatteryLe vel=133,LEDBrightness=0,NightThreshold=64,DayThreshold=80,Tr ansitionInterval=60,LightFlags=64,DarkFlags=0,LightIntervalH B=60,LightHysteresis=5,LightHarvest=0,OffBtnTimeOut=33,TempC alibration=0,OpFlags2=87,PowerSource=Battery
                            FirmwareVer=46
                            HopData=561,550,7,4
                            LastContact=5/27/2022 11:32:56 AM
                            Link 1=E2 01 3B 51 08 00 00 01 1
                            Link 5=E2 10 3B 51 08 00 00 10 5
                            Link 6=E2 0B 3B 51 08 00 00 0B 6
                            LinksDownloaded=1
                            NumLinks=6
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=27
                            [Device 15]
                            DatabaseDelta=4
                            DeviceID=2B.01.A1
                            DeviceLocation=Main
                            DeviceName=Front Door Sensor
                            DeviceType=1011
                            FirmwareVer=43
                            HopData=222,212,7,3
                            LastContact=5/27/2022 12:03:42 PM
                            LinksDownloaded=1
                            NumLinks=4
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=8
                            [Device 2]
                            DatabaseDelta=14
                            DeviceID=47.22.51
                            DeviceLocation=Den
                            DeviceName=Couch Lamp - Left
                            DeviceType=010E
                            EEValues=LEDBrightness=0,DefaultOnLevel=254,DefaultRampRate= 31,OpFlags1=96
                            FirmwareVer=43
                            HopData=3471,3470,0,1
                            LastContact=5/11/2022 1:42:13 PM
                            Link 1=A2 00 3B 51 08 00 1C 00 1
                            Link 2=E2 01 3B 51 08 03 1C 00 2
                            Link 3=E2 01 2F 44 02 00 00 01 3
                            Link 4=A2 01 3B 51 08 FF 1F 01 4
                            Link 5=A2 FE 3B 51 08 FF 1F 01 6
                            LinksDownloaded=1
                            NumLinks=5
                            PollingInterval=0
                            Protocol=3
                            RecentDatabaseDelta=14
                            TotalInteractions=356
                            [Device 3]
                            DatabaseDelta=47
                            DeviceID=2C.76.43
                            DeviceLocation=Den
                            DeviceName=Den - Cans
                            DeviceType=0135
                            EEValues=LEDBrightness=17,DefaultOnLevel=254,DefaultRampRate =28,OpFlags1=0,OpFlags6=0
                            FirmwareVer=43
                            HopData=4059,4058,1,0
                            LastContact=5/11/2022 1:42:19 PM
                            Link 1=AA 00 3B 51 08 00 1C 01 2
                            Link 2=EA 01 3B 51 08 03 1C 01 3
                            Link 3=AA 14 3B 51 08 FF 1F 01 4
                            Link 4=E2 01 3B 51 08 00 00 01 6
                            Link 5=A2 FE 3B 51 08 FF 1F 01 7
                            LinksDownloaded=1
                            NumLinks=5
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=50
                            [Device 4]
                            DatabaseDelta=5
                            DeviceID=2C.76.97
                            DeviceLocation=Den
                            DeviceName=Mantel
                            DeviceType=0135
                            FirmwareVer=43
                            HopData=3985,3983,1,1
                            LastContact=5/11/2022 1:42:29 PM
                            Link 1=AA 00 3B 51 08 00 1C 01 3
                            Link 2=EA 01 3B 51 08 03 1C 01 4
                            Link 3=AA 14 3B 51 08 FF 1F 01 5
                            Link 4=E2 01 3B 51 08 00 00 01 7
                            Link 5=A2 FE 3B 51 08 FF 1F 01 8
                            LinksDownloaded=1
                            NumLinks=5
                            PollingInterval=0
                            Protocol=3
                            [Device 5]
                            DatabaseDelta=5
                            DeviceID=2C.38.6A
                            DeviceName=Nook
                            DeviceType=011F
                            EEValues=LEDBrightness=32,DefaultOnLevel=234,DefaultRampRate =31,OpFlags1=36
                            FirmwareVer=41
                            HopData=3337,3322,0,15
                            LastContact=5/11/2022 1:42:39 PM
                            Link 1=E2 01 3B 51 08 03 1F 00 4
                            Link 2=A2 00 3B 51 08 00 1F 00 5
                            Link 3=A2 07 3B 51 08 FF 1F 00 6
                            Link 4=A2 FE 3B 51 08 FF 1F 01 8
                            LinksDownloaded=1
                            NumLinks=4
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=34
                            [Device 6]
                            DatabaseDelta=1
                            DeviceID=47.1C.D9
                            DeviceLocation=Deck
                            DeviceName=Deck Ceiling
                            DeviceType=010E
                            FirmwareVer=43
                            HopData=3873,3813,18,42
                            LastContact=5/11/2022 1:42:17 PM
                            Link 3=A2 FE 3B 51 08 FF 1F 01 3
                            LinksDownloaded=1
                            NumLinks=3
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=29
                            [Device 7]
                            DatabaseDelta=5
                            DeviceID=2C.35.26
                            DeviceType=011F
                            EEValues=LEDBrightness=32,DefaultOnLevel=191,DefaultRampRate =31,OpFlags1=96
                            FailedInteractions=2
                            FirmwareVer=41
                            HopData=4156,2899,4,1253
                            LastContact=5/11/2022 1:42:25 PM
                            Link 1=A2 00 3B 51 08 00 1F 00 5
                            Link 2=E2 01 3B 51 08 03 1F 00 6
                            Link 3=A2 FE 3B 51 08 FF 1F 01 7
                            LinksDownloaded=1
                            NumLinks=3
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=98
                            [Device 8]
                            DatabaseDelta=7
                            DeviceID=2C.77.0C
                            DeviceLocation=Outside
                            DeviceName=Back Flood
                            DeviceType=0135
                            EEValues=LEDBrightness=17,DefaultOnLevel=254,DefaultRampRate =28,OpFlags1=0,OpFlags6=4
                            FirmwareVer=43
                            HopData=4197,4195,1,1
                            LastContact=5/11/2022 1:42:11 PM
                            Link 1=AA 00 3B 51 08 FF 1C 01 2
                            Link 3=E2 01 3B 51 08 00 00 01 7
                            LinksDownloaded=1
                            NumLinks=4
                            PollingInterval=0
                            Protocol=3
                            RecentDatabaseDelta=7
                            TotalInteractions=38
                            [Device 9]
                            DatabaseDelta=5
                            DeviceID=2B.83.AB
                            DeviceLocation=Front Porch
                            DeviceName=Front Porch
                            DeviceType=021A
                            EEValues=LEDBrightness=0,OpFlags1=100
                            FirmwareVer=41
                            HopData=3986,3961,7,18
                            LastContact=5/11/2022 1:42:23 PM
                            Link 1=E2 01 3B 51 08 00 00 01 4
                            Link 2=A2 FE 3B 51 08 FF 1F 01 5
                            LinksDownloaded=1
                            NumLinks=2
                            PollingInterval=0
                            Protocol=3
                            TotalInteractions=31
                            [Group 1]
                            Controller=47.22.51:1
                            GroupLocation=Den
                            GroupName=Couch Lights Group Controller
                            GroupNum=1
                            NumParticipants=2
                            Participants=2F.44.02:1,100,31,47.22.51:1,100,31
                              please install the latest beta .11 and lets see what additional info is logged
                              https://forums.homeseer.com/forum/hs...-beta-4-0-3-11
                              Mark
                              HS3 Pro 3.0.0.534
