Insteon Motion Sensor Events
This topic is closed.
    #16
    I've loaded the Beta plugin. The log file is attached. Thanks.
    log(21).txt
      #17
      ok. let me know if you see the same errors/exceptions logged like before.
      Mark
      HS3 Pro 4.2.19.5
        #18
        My Insteon Hub disconnected from the router which stopped all HS4 events. Once I got the Hub reconnected to the router I restarted HS4 and re-enabled the Insteon PlugIn. The system seems to be working as it should with no error messages appearing in the log. It appears the 11 beta fixed the issue. Thanks for your help.
          #19
          thanks for reporting back.
          Mark
          HS3 Pro 4.2.19.5
