I successfully loaded the plugin. The plugin keeps returning an error "Cannot contact the Insteon Interface on 10.0.0.64:25105. Please check the Settings page." I can reach the hub through my browser so not sure what to do.
Login to Insteon Hub through plugin
This topic is closed.
also try power cycling the insteon hubMark
HS3 Pro 3.0.0.534
try again, if you get the same result, then there is nothing programmed into the hub link databaseMark
HS3 Pro 3.0.0.534
two options
(1) remove the wallplates to the get the insteon id on the front of each device. the register with the plugin Devices/Add Device button
(2) use the the plugin Devices/Tap Add Device. you must then run the "program device for homeseer" on each device you tap add (this is mentioned on the tap add page). please dont forget to do this otherwise things wont work.Mark
HS3 Pro 3.0.0.534
Restart the plugin from the hs plugins manage page
If that doesn’t work. Power cycle the Insteon hubMark
HS3 Pro 3.0.0.534
Please help me.....I have followed ALL DIRECTIONS TO A "t" ........Error cannot find interface .......hub is find have all correct info....have recycled both the hub and Pi....what shall I do next......can communicate with hub thru network........Please give me specific diagnostic tests to resolve connection problem ....
find your device on the plugin Devices page.
Mark
HS3 Pro 3.0.0.534
