Hi there.
I own an Insteon Hub, Insteon Dimmer plugs, Insteon dimmer switches Insteon Sensor switches and Insteon Thermostats.
The Hub came back online on 6/7/2022 but we do not have any idea whether it will stay like that.
I came across your product (Homeseer and the plugins) and interesting in purchasing it.
What are the minimum requirement for transferring the Insteon devices over to your platform. I want to make sure that all my devices will work including the thermostats.
Questions:
Any help will be appreciated. Thanking you in advance
Cyrus
Questions:
- Is the transition painless?
- Will all my switches including the thermostats work with Homeseer?
- Do I still need to keep my Insteon hub once I start transition and start using your Homeseer?
- Will the products below work? (need help in deciding what is best to purchase)
- HomeSeer HomeTroller Pi Smart Home Hub (is this the minimum requirement)
- Insteon Software Plugin (is this the minimum requirement)
- Is there a plugin for the Insteon Thermostats too?
- HomeSeer HomeTroller Plus Smart Home Hub
- Besides the difference in the cost, What is the advantage between 1) and 4)?
Cyrus
