Changes
To Install a Beta
- Fixed MS II programming messages (4.0.4.1)
- Revised Ballast Dimmer support (4.0.4.1)
- Added status/graphics for Smoke Bridge (4.0.4.2)
- Improve insteon.ini stability (4.0.4.2)
- Added local port list to Interface Port field (4.0.4.2)
- Fixed issue when deleting a group that affected the display of the Group controller (4.0.4.4)
- Changed Group Number display to match Group:# address on HS device (4.0.4.4)
- Changed group cleanup option to a per group setting (4.0.4.6)
- Revised Groups management page to include sorting and separate Location value (4.0.4.6)
- Changed Remotelinc2 configuration to support dimming triggers (4.0.4.7)
- Fixed Group selection UI feature (4.0.4.7)
- Fixed Ramp Down trigger configuration (4.0.4.8)
- Revised Ramps trigger device list(4.0.4.9)
- Revised Interface Port available ports display (4.0.4.9)
- Moved the statistics to a new insteon_stats.ini file (4.0.4.10)
- Improved insteon.ini stability and reliability (4.0.4.10)
- Fixed bugs related to group control and settings for switchlinc dimmers (4.0.4.11)
- Fixed Replace Device routine (4.0.4.12)
- Fixes Insteon Actions and Triggers for upcoming SDK 1.4.3 changes (4.0.4.13)
To Install a Beta
- Backup your current setup. see the HS Tools/Backup page
- Disable the current plugin on the Plugins/Manage page
- Go to the HS Plugins/Add page
- Enable the Show Beta Plugins option
- Search for Insteon
- Select the MNS Insteon Beta, then click Install
- if you get an error, restart HS4 first and then try again
