Running HS 4.2.14.0 and MNS Insteon 4.0.4.10
I have a LampLinc dimmer that's flaked out and I'd like to swap it out for a replacement. I'm attempting to use the Replace Device functionality in the device screen and get the message "An Error occurred" after entering the replacement device ID. There is no entry in the log to indicate what error occurred. This is a relatively new install - I didn't upgrade from HS3 to 4.
Date/time=27/09/2022 14:54:55 CDT
Version=HS4 Standard Edition 4.2.14.0 (Linux)
MONO Version=Mono JIT compiler version 6.12.0.182 (tarball Tue Jun 14 22:42:28 UTC 2022)
License=Registered
Confguration File=/usr/HomeSeer/Data/HomeSeerData.json
Uptime=0 Days 22 Hours 10 Minutes 11 Seconds
Lan IP=127.0.0.1 (homeseer4-pi)
Device Count=344
Event Count=52
Plugins Enabled=AK Bond:,HS MyQ:,iRobot:,LIFX:,Sonos4:,Honeywell Lyric:,Z-Wave:,MNS Insteon:
Modules/Threads=90 Modules, 62 Threads
Available Threads=399
HomeSeer Memory Used=186 Mbytes
Plugins Installed=AK Bond 4.0.4.2,BLOnkyo 4.0.8.0,Honeywell Lyric 4.1.2.1,HS MyQ 4.0.9.0,iRobot 4.22.25.2,LIFX 4.0.7.0,MNS Insteon 4.0.4.10,Sonos4 4.0.1.12,Z-Wave 3.0.10.0
License=Registered
Device Count=344
Event Count=52
