I've been looking for a default on level and a default ramp rate but I can only find them on my LampLinc's and on my one keypad dimmer. All my 2476D dimmer switches don't seem to have this setting. Is there a way to change the default on levels and ramp rates?
Default On level
is this an i1 protocol switch?
what is the 4 digit code (####) reported on the device in the plugin
Mark
HS3 Pro 4.2.19.5
you must power cycle (pull the set button for a second) any i1 switches after you change the settings. the changes does not take affect immediately. this is just a limitation of i1 devices.
you should see the following for an i2 switch
Mark
HS3 Pro 4.2.19.5
Mark
Thanks for the reply and for the info on the i1 switch. Yes, that worked.
How do I get my i2 screens to look like yours does? The kitchen light dimmer I showed you up thread is an i2 switch. All of my i2's look like that with the 'LED Brightness' and the 'Default On Level' missing. I've restarted the HS software, rebooted the HomeTroller, approached it through the Insteon plugin 'Devices' choice and through the HS4 'Devices' page. When I navigate to that page, the i2's always show the way it looks in my screenshot.
Bob
i think i found the issue in the code
do you have any other swlitchlinc dimmers with type (0101) that are i1 ?
Mark
HS3 Pro 4.2.19.5
Mark
I have one i1 device (SwitchLinc V2 600W Dimmer (0101) with Firmware 27) that shows the 'Default In Level' and the 'Ramp Rate'
I have eight i2 switch dimmers (SwitchLinc V2 600W Dimmer (0101) with Firmware 37) that do NOT show the 'Default In Level' and the 'Ramp Rate'
I have ten i2 LampLinc's (LampLinc V2 3-Pin (0100) with Firmware 37) that do show the 'Default In Level' and the 'Ramp Rate'
I have one i2CS KeypadLinc (Dual-Band KeypadLinc Dimmer (0142) with Firmware 45) that do show the 'Default In Level' and the 'Ramp Rate'
The i2 SwitchLinc's seem to be the odd man out here.
Bob
as a test, and if you are comfortable doing the following, you can override the plugin code with the following changes
stop the insteon plugin
edit the hs/config/insteon.ini file
find the [device x] section of the device in question
change the line Protocol=1 to Protocol=2
save & close the file
restart the plugin
check if the settings are available on the i2 switch (type 0101)
please note: i dont believe the v4 plugin has default on level, and ramp rate settings for pure i1 devices (the code is different). you will need to set this on the physical switch.Mark
HS3 Pro 4.2.19.5
Originally posted by bobchase View PostMark
36 of my 37 devices were already set to Protocol=2 in the Insteon.ini file when I went to look. The i1 wall switch was/is Protocol=1.
Bob
there shouldn't be any settings for the i1 switch.
i guess i need to post another beta to undo the chagne i made related to this.Mark
HS3 Pro 4.2.19.5
BobMark
HS3 Pro 4.2.19.5
I can test anytime you want.
Presently the Default On Level and Ramp Rate is shown on the i1 switch'es page and the i1 switch did respond to the Default On Level change I made after you told me about the need to power-cycle it.
Bob
i'll post a new beta later this evening.Mark
HS3 Pro 4.2.19.5
I posted 4.0.4.11 with some bug fixes to the updater.Mark
HS3 Pro 4.2.19.5
