MNS Insteon Plug-In description, "A native HS4 Insteon plugin that also supports X10" indicates that it supports X10. Will it support X10 WITHOUT an Insteon Hub? Everything I have is X10 only; I have no Insteon devices.
X-10 support without Insteon Hub
you need a plugin compatible x10 controller such as a PLM
if you only need x10 support, there are other plugins and x10 only controller that you should considerMark
HS3 Pro 4.2.19.5
